TSB info for "Tire road noise when braking"
Old Mar 15, 2003 | 03:10 AM
shagz's Avatar
shagz
Default TSB info for "Tire road noise when braking"
Got a copy from my dealer. They have ordered new front tires for me, at no cost to me. It's upto youe dealer to decide if you 'deserve' new tires or not.
Here is the info, as it appears on the TSB. Hope this helps.
TSB: 2003 350Z: Tire Road noise when braking
Classification: WT03-001
Reference: NTB03-006
Date: Jan 23, 2003
Applied VINS: Vehicles built before: JN1AZ34E93T004958
JN1AZ34D63T104023
Applied Date: Vehicles built before Sept 19, 2002
If you confirm:
An applied vehicle shows the following symptoms when braking moderately:
- excessive tire "roar" or "growl" noise
- mostly when braking at speeds below 30 mph
Actions:
- Verify the incident noise as described above
- Check alignment. Adjust(if needed)
- Rotate front tires from side to side (dismounting tires from wheels)
Service procedure:
1. Verify noise as described above
2. Check the vehicles front end alignment and adjust toe-in, if needed
3. Once toe-in has been checked and adjusted (if necessary), rotate tires.
Old Mar 15, 2003 | 03:12 AM
shagz's Avatar
shagz
The above mentioned problem addressed in the TSB is also referred to as tire cupping/feathering.
Old Mar 15, 2003 | 03:17 AM
shagz's Avatar
shagz
Sorry...I keep forgetting things...
My dealer ordered the tires for me a couple of months back, but when they came in they realized that they had ordered the rear tires instead of the front. DOH
Anyway, they have ordered the correct tires this time, and have rotated the tires from side to side, which has helped significantly with the "growl".
They also told me that there were only 10 of these tires available in the entire north america, and they have ordered 8. If you live in jacksonville and have the symptoms, contact John Norton at 880-3000 (Coggin Nissan @ Avenues)
Old Mar 15, 2003 | 06:29 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
There are only 10 of these tires available? hopefully I am getting the other 2
Dealer has agreed to order tires for my tire feathering problem... I have 10,250 miles..
Old Mar 16, 2003 | 08:16 AM
stevew's Avatar
stevew
Exclamation
This seems to be the first formal acknowledgement by Nissan about the tire feathering issue which has been one of the big topics on the forum. With the VIN #'s specified, should this be posted at the top of the forum for a while? It seems pretty important.
Old Mar 16, 2003 | 02:24 PM
zwindsor's Avatar
zwindsor
Twisty addict
Any chance you can post the actual TSB?
Old Mar 16, 2003 | 02:51 PM
shagz's Avatar
shagz
Unfortunately I don't have a scanner. I can mail it to one of you guys and you can put it up. Or just give the TSB# to your dealer and get a copy from them. PM me if you want me to mail it to you.
Old Mar 16, 2003 | 08:10 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
your dealer knows about this TSB. When I took my car last week to have it checked, the service advisor alrady knew about the TSB. All they need to do is look it up...
Old Mar 17, 2003 | 03:46 PM
grebmohr's Avatar
grebmohr
Unhappy
I have the exact symptoms as the TSB but my vin is 9966.
I guess I am gonna have to pay for service then fight it out with NNA.
Maybe, for once, the dealer will save me the trouble and file it for me. ? ..? !
Probably not.
Old Mar 17, 2003 | 07:46 PM
shagz's Avatar
shagz
The dealers/nissan is being "fuzzy" about this problem. At first, the dealer had told me that there was a peoblem with the manufacturing process of the tires which were put on that vin range. But then the TSB say to check the alignment......That doesn't compute.....it's a conspiracy I'm sure. j/k
And now I'm having rust spots show up in the rear hatch jamb. Jesus...what's next ?
Old Mar 17, 2003 | 08:21 PM
grebmohr's Avatar
grebmohr
Rust!?!? Yikes Any clue as to why yet? Can you post a picture of the spots? This a truely scary development. Is the French side of your car showing? I hope not for you, me or all of us.
Old Mar 31, 2003 | 12:01 AM
zeelee's Avatar
zeelee
Default Re: TSB info for "Tire road noise when braking"
Date: Jan 23, 2003
JN1AZ34D63T104023
If you confirm:
Actions:
Service procedure:
What did Nissan change on Sept 19, 2002? What is the difference between vehicles built before and after Sept 19, 2002 - could that be the answer to the problem? Could someone please enlighten me"
Old Mar 31, 2003 | 07:32 AM
zwindsor's Avatar
zwindsor
Twisty addict
Default Re: Re: TSB info for "Tire road noise when braking"
They most likely found an alignment problem, whether it be the specs or just sloppy assembly line work. Doesn't seem to be a part defect.
Old Mar 31, 2003 | 07:52 AM
mytalon's Avatar
mytalon
JN1AZ34D63T104023
How do you determine your build date?
Obadabot
Jun 18, 2023 11:31 PM
