Royal Purple installed in the tranny and differential today.
Old Nov 6, 2006 | 07:11 PM
aren21's Avatar
aren21
^thanks dude, thats what I figured but I wasnt sure.
Old Nov 6, 2006 | 07:39 PM
Gary King's Avatar
Gary King
Royal Purple is great stuff, been using it in the engine, tranny and diff of the Z for two years now and love it. If they made hair gel I'd probably use that too.
Old Nov 6, 2006 | 09:31 PM
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
LMAO!!
I ordered my RP fluids. Now to schedule my over due check-up to get all fluids changed out.
Old Nov 7, 2006 | 11:48 AM
mberthia's Avatar
mberthia
The trans fluid should be GL4 while the Diff should be GL5. What does the RP meet? 4 or 5.
I have Amsoil in my trans since last year and I don't really like it. At operating temps its fine but cold, the trans is hard to shift in first and second.
By cold I mean less than 50F outside.
How is RP in colder weather ?
Old Nov 7, 2006 | 11:51 AM
Nexx's Avatar
Nexx
meets both GL4 and GL5.
Old Nov 7, 2006 | 02:09 PM
DavesZ#3's Avatar
DavesZ#3
Originally Posted by Nexx
for the most part. ive read a few people who have changed to redline and felt little or no difference. i have yet to see that from anyone who has tried RP.
There's a few of us out there who switched to RP and saw no improvement or in my case, it's worse. When cold, I can't downshift from 2nd to 1st unless I come to a complete stop.
The upside is that I've noticed over the last couple of weeks, my gas mileage has gone up about 2 mpg.
Old Nov 7, 2006 | 02:12 PM
DavesZ#3's Avatar
DavesZ#3
While it meets both, Maxgear goes not have the additives in it that make most GL5's harmful to parts of the tranmission. Therefore it's okay to use it in both the trans and diff.
Old Nov 7, 2006 | 10:52 PM
350zjae's Avatar
350zjae
My 1-2 shift is a little notchy and sometimes I have to be at a deadstop to downshift from 2 to 1. How can I change the transmission and diff oil to Royal purple? Do i just buy 6 quarts and ask the dealership to do this? Also, I'm only at a 1000 miles, should I wait?
Sorry for the newbie questions
Old Nov 7, 2006 | 10:55 PM
zand02max's Avatar
zand02max
Looks like I will be changing my Diff and tranny when I return home next year.
Question: Was the tranny and diff hard to change?
Old Nov 7, 2006 | 11:09 PM
Nexx's Avatar
Nexx
Link to DIY differential and tranny oil change:
https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/131098-changing-the-differential-transmission-oil.html
this will answer most questions concerning the difficulty and how much oil you need.
Old Nov 7, 2006 | 11:27 PM
zand02max's Avatar
zand02max
Yeah, I saw that thread, just curious if it was hard when you changed it, thanks,
1 outta 10, 1 being the easiest?
Old Nov 7, 2006 | 11:30 PM
Nexx's Avatar
Nexx
lol, my mechanic said it was a breeze. drain then fill. thats it. took him less then 30 minutes.
Old Nov 7, 2006 | 11:35 PM
jsupetran's Avatar
jsupetran
3 out of 10 imo. Just takes time and is messy.
Old Nov 7, 2006 | 11:41 PM
zand02max's Avatar
zand02max
Cool, looks pretty simple!
Looks like I will do all of this in one day since I will have access to a lift.
1. Nismo Exhaust install
2. Pop Charger install
3. 06 tailight install
4. Change oil/filter
5. Change Diff fluid
6. Change Tranny fluid
7. Put Volks back on and wax on/wax off!
Should be fun. If anyone wants access to a lift and located near San Angelo, TX. I'll pay your lift fee, plus help you change your fluids if you help me do mine,
Old Nov 8, 2006 | 11:19 AM
Nexx's Avatar
Nexx
bewarned, tranny fluid smells like ***. try to get as little of it on you as possible.
Old Nov 8, 2006 | 11:22 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
My diff fluid smelled WAY worse than my tranny fluid, but the sentiment is the same.
I would rate changing the trans/diff about a 3/10 also... the only thing that is "difficult" is lifting the whole car to be level.
pop charger install, and tail lights install, you don't need to lift the car BTW
Old Nov 8, 2006 | 12:12 PM
zand02max's Avatar
zand02max
LOL, I know, I will do that at home,
Old Nov 8, 2006 | 05:40 PM
  #38
SoulDesign's Avatar
SoulDesign
i just changed my tranny/dif with RP max gear. not too hard at all, i bought a suction pump for 10 bucks at auotzone, i dont think i cldve done the diff without it.
anyway. honestly.....im not as impressed as i thought i would be. everything seems a little quieter but first feels a little harder to engage than before. besides that, everything seems very smooth. i do however smell somthing burning from around the transmission, and i saw what looked like a little puff of smoke at one point. ive not had a chance to lift it back up to actually crawl under and look, but ive laid down and watched it for awhile, and never saw a single drip? is it possible for it to be leaking just enough to be burning on the exhaust, but not dripping to the ground? ive even looked at the ground where its been sitting while its parked, and dont see anything? i thought i wiped everything clean...but maybe i left some drips on the exhaust?
Old Nov 8, 2006 | 06:06 PM
  #39
aren21's Avatar
aren21
you probably just spilled some oil somewhere and its getting hot and burning, or maybe you didnt tighten the bolt enough or something. If its just spilled fluid the smoke should go away soon.
Old Nov 8, 2006 | 06:20 PM
  #40
SoulDesign's Avatar
SoulDesign
update..... i got worried about it leaking so i went down and took a closer look with a flashlight. its 10pm and im layin under my car ;o)
evrything is fine. nothing is leaking, i just spilled a considerable amount actaully on the exhaust while i was using the pump gun. lol. messy, messy. my friend "helping" me, wouldnt even hand me anything, so i ended makin a mess, nockin stuff over as crawled in and out on my back.
all is well
