2005 Z Engine knocking
Old Nov 13, 2006 | 04:01 PM
jetpilot1's Avatar
jetpilot1
Default 2005 Z Engine knocking
Engine has a knocking sound at idle and knock increases with RPM. Took it to dealer today and they told me to bring it in the morning and leave it. I bought the car new (it was a "demo" driven by the owner of the dealership. It had 3,700 miles on it and it knocked when I bought it. I now have 6,900 miles and I thought it was the fuel injectors, but a mechanic friend told me to have Nissan look at it. Any thoughts?
Old Nov 13, 2006 | 04:12 PM
HighwaySpeed's Avatar
HighwaySpeed
Question
Welcome!
What grade of gasoline do you use?
Have you added any gasoline to the car, since you've owned it?
How long has the car been this way?
Why would you buy a car from a new car dealer that had a knocking sound?
Old Nov 13, 2006 | 04:22 PM
jetpilot1's Avatar
jetpilot1
Always used 93 Octane. I didn't realize the car was knocking until about a week after the purchase. Like I had mentioned, I thought it was the fuel injectors, I guess I'll find out tommorow when Nissan looks at it. I've had the car for a year and a half and I've only put 3000 miles on it.......
Old Nov 13, 2006 | 05:08 PM
ZCARBANDIT's Avatar
ZCARBANDIT
Sounds like detenation.But with only 7000 miles on it...hum
Old Nov 13, 2006 | 05:11 PM
1FlyZ's Avatar
1FlyZ
either way you should be under warrenty and shouldnt have to pay for anything. CONGRATS on the new car! Biggest advise is search on this thread before posting! you will save yourself from alot of flaming.
But keep us informed on what they say. I would say detenation also.
Old Nov 13, 2006 | 05:16 PM
jetpilot1's Avatar
jetpilot1
You don't think it's a bearing problem? Why detonation, I use the proper fuel.... Anyway, when the dealer looks at it I'll post the answer. Thanks for your replies.
Old Nov 13, 2006 | 05:19 PM
ZCARBANDIT's Avatar
ZCARBANDIT
I don't think that a bearing would be going with only 7000 miles. I know that some of the chevy trucks were being overborred at the factory causing piston slap in new vehicles. But this is different alltogether. Hard to say w/o being with the car.
Old Nov 14, 2006 | 01:39 PM
dlciii's Avatar
dlciii
You may want to check your oil level.
I seem to have had a similar problem. At first I thought it might be an engine warm up thing. Then I noticed when driving that the oil pressure was extremly low. I know the oil pressure technically has nothing to do with the oil level, but.....if the oil level is too low, you will always have low pressure because there physically is not enough oil to push through the closed system.
My car only has 8000 miles on it, and I have only had regular (no synthetic) oil in the car. When I checked, I was about 2 qts down!!!! As soon as I added oil, waalaa, no more knocking!
There is another thread in this forum about the 350 burning oil. I am gonna take my car to the dealer to get an oil consumption test performed. Oh, BTW, the only mod to my car (35th anniv) is the motordyne iso thermal plenum spacer upgrade and a K&N slip in, which should have nothing to do with the oil!
Old Nov 14, 2006 | 02:50 PM
jetpilot1's Avatar
jetpilot1
Never a problem with oil consumption, had the car at the dealer today, they all heard it and told me they don't know what it is..... They want me to drive it and see if it gets worse before they can diagnose the problem. I drove away, but their answer just isn't good enough. Called them back and told them that it just isn't right for me to be driving a $38,000 car with 6900 total miles on it with a knocking sound.... They agreed and they told me to bring it back and they will make some phone calls, we'll see. BTW, had the oil changed yesterday, my car has never been low, also a 35th Anniversary.
Old Nov 14, 2006 | 07:16 PM
jjulich's Avatar
jjulich
Do you hear this knock from the top of the engine with the hood up, or at the driver's or passanger's side near the front wheel? I hear a ticking sound (once per revolution) at the driver's side front wheel, but not from on top the hood. Don't know if this an exhaust leak, or if it is natural.
Old Nov 18, 2006 | 05:24 PM
jetpilot1's Avatar
jetpilot1
You can hear the knocking sound from all the locations you mentioned....Nissan told me it is a "noisy" Fuel Damper Assembly and there is a TSB out for this issue. I located the TSB at www.nissanhelp.com. Part is on order. We'll see....
Old Dec 8, 2006 | 07:04 AM
drap660's Avatar
drap660
Did this work out for you???
Old Dec 8, 2006 | 08:11 AM
khyber's Avatar
khyber
I had an engine knocking problem... only when I hit about 3k rpms and accelerating slowly (maybe I just couldn't tell when I floored it cause the engine was too loud? I dunno). It would just be this annoying clicking noise and like you said you had, it would get worse with acceleration, the higher my RPMs were the worse it was. You have the revup engine, that's what's in the 35th anniversary, right? My car is in the shop now and is getting the engine replaced as we speak (and they have me in a rented chevy aveo that makes me want to shoot myself). I have an '06 base but I'm pretty sure we both have the rev up engines. My problem was in the drivetrain I think and it's all getting replaced under warranty, so have them check it out. Thanks
-Max
Old Jan 23, 2007 | 09:50 AM
jjulich's Avatar
jjulich
I am experiencing the same problem. Did this fuel damper work for you?
Thanks,
Jeff
Old Jan 23, 2007 | 01:18 PM
Cannysage's Avatar
Cannysage
3700 miles is not a new car. you better hope it's not a bent rod.. it could've been a Turbo'd car that went stock.
Old Jan 23, 2007 | 07:02 PM
stein's Avatar
stein
Hit n run poster
Wonder what the problem/solution was...
Old Jan 24, 2007 | 10:15 AM
jjulich's Avatar
jjulich
Does everyone have a ticking sound from their engine at idle? I need to know if this is normal. Maybe 2 times per second?
Old Sep 26, 2007 | 05:19 PM
victor1's Avatar
victor1
Originally Posted by stein
Hit n run poster
Mine does the same thing. So how is your car doing?
Old Sep 26, 2007 | 06:27 PM
04LIQUIDSILVER's Avatar
04LIQUIDSILVER
My car does the same thing .... any solutions? My is an 04 and have 36k milles on it
Old Oct 3, 2007 | 01:01 PM
fordslowcus's Avatar
fordslowcus
I've got ticking I think its the type that gets fixed with valve clearance adjustment.
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
kyin
Oct 15, 2015 05:54 AM
