Engine rev max out at 2k rpm
Old Nov 15, 2006 | 02:02 PM
bamyi's Avatar
bamyi
Default Engine rev max out at 2k rpm
I'm having some issue with my Z lately, especially after installing the metrodyne spacers. I've triple check everything and can't find the cause.
Question: Once in a while my engine will act like if it's reach the rev limit when it hits 2,000 rpm. What can cause that?
I've also noticed that my car heats up pretty quickly (after 1 min from start up when it's 30 degrees out). I've never noticed it before and I don't know if this is normal or it could be associated with the above problems.
Any ideas, suggestions would be greatly appreciated. Thanks in advance guys/gals.
Old Nov 15, 2006 | 02:04 PM
playa6tnine's Avatar
playa6tnine
do you have an aftermarket intake? maybe its loose up top or down low.
did you tighten the spacer with torque wrench?
MAsSIVrOOM
Oct 20, 2023 10:50 AM
etkms
Jun 19, 2022 06:30 PM
AbyteZero
Sep 22, 2015 09:17 AM
Calinismo350z
Sep 14, 2015 04:04 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
