Help me find this Clicking noise.
Old Dec 20, 2006 | 04:45 PM
StraySheep's Avatar
StraySheep
Question Help me find this Clicking noise.
After about 10,000 miles on my 2006 Z, there's this clicking noise that wouldn't go away and it's starting to bother me more and more.
The noise comes from the rear passenger side. The click sounds just like a rock hitting the inside of the rear wheel fender. Or some plastic hitting on metal on the inside of the car.
It occurs sometimes when the road gets bumpy.
I took everything, including the spare tire, out of the trunk and made sure everything tied down. But still the noise would not go away.
Any suggestions on where the noise can potentially come from is appreicated.
Old Dec 20, 2006 | 04:51 PM
Mike Wazowski's Avatar
Mike Wazowski
welcome to the wonderful world of a Nissan sports car.
I would suggest an ear plug for your right ear if you dont wanna hear it anymore
Old Dec 20, 2006 | 04:53 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
https://my350z.com/forum/2003-2009-nissan-350z/197329-the-top-100-common-questions.html
Please read second question on post #22
After doing so, I'd also suggest to also read the rest of the thread.
Old Dec 20, 2006 | 05:25 PM
I think that one or two members mentioned something about a clicking rear axle. Maybe thats it?
Old Dec 20, 2006 | 06:40 PM
glowz825's Avatar
glowz825
You need to put a shim in between the trunk latch hook and and the trunk lid. You will need to remove the plastic cover to get to the 2 bolts that hold it on
Old Dec 20, 2006 | 07:09 PM
ZCARBANDIT's Avatar
ZCARBANDIT
Replace everything with carbon fibre, then all your troubles and inabitions will fly away.
Old Dec 20, 2006 | 07:20 PM
StraySheep's Avatar
StraySheep
Q: I hear a clicking sound sometimes. What is that? Sounds like it's coming from the rear of the car?
A: Beware of a slight metallic clicking sound coming from the rear of the car. It is due to the rear axle not being properly lubricated. If your car has this problem, you will usually hear this clicking sound when (1) in an enclosed space or driving near a hard wall, (2) driving without radio and with the window down (try turning off A/C if you still aren't sure), and (3) starting to move from a halt. The clicking sound is more pronounced while turning, or so it seems.
If you have the clicking, your car is due for a "Technical Service Bulletin" or "TSB" repair for rear axle clicking, which is covered under warranty. Take it to a dealer, and don't leave until they agree to fix it.
It seems like this rear axle might be the cause.
Anyone got a picture of exactly were on the rear axle is the noise coming from? Is it easy for the dealer to fix? I don't want them to be taking my Z apart and have more problems afterwards.
Old Dec 20, 2006 | 07:22 PM
ZCARBANDIT's Avatar
ZCARBANDIT
Yeah, it's easy to fix.
Old Dec 20, 2006 | 08:04 PM
For a diagram and details check the appropriate service bulletin.
Old Dec 20, 2006 | 11:09 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
Question Straysheep, is it a clicking or clunking?? Think about it, 2 slightly different things.
Old Dec 21, 2006 | 07:03 AM
THE TECH's Avatar
THE TECH
Search is your friend.
Old Dec 21, 2006 | 09:09 AM
StraySheep's Avatar
StraySheep
Actually, it sounds more like a "Tack". Just like how the rocks hit the inside of the wheel fender when you drive over small rocks.
Old Dec 21, 2006 | 06:40 PM
Netko350Z's Avatar
Netko350Z
Here is an idea...Do you have aftermarket rims? I had metal valve stems and one of the bolts inside the rim had came loose. It would click inside the rim and eventually go away when the wheel would speed up.
Old Dec 22, 2006 | 04:31 AM
GATORZ's Avatar
GATORZ
I had an 03 pre-order that had the rear axle click and now I have an 06 that has it. You would think after 3 years they would have taken care of this. I also get a clicking/ticking noise from the rear if the VDC or traction control(slip light) occurs. Never had that on the 03 when I lost traction. I don't think it's right. Throw in MAJOR oil consumption and you have a real nice piece of crap for $36k. My bad for not keeping the 03.
Old Dec 24, 2006 | 06:03 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
One other possibility, could be rocks/small stone caught in your control arms. If it is this is very easy to blow out with the correct equipment.
But definitely have the axle clicking thing checked out too.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
