Postioning a radar detector
Old Mar 26, 2003 | 12:12 PM
ZGone's Avatar
ZGone
Question Postioning a radar detector
Since the outlet for the power cord is so poorly placed I am considering hard wiring the detector into the dome line circut. I could position the unit on top of the rearview mirror. My concern is how would the "tinting" located around that area of the windshield effect the detector? Anyone have experience with the wiring and/or position for a detector?
Thanks
Old Mar 26, 2003 | 12:58 PM
MSCHOEN2U's Avatar
MSCHOEN2U
Default WINDOW TINTING
I had the upper part of the windshield tinted, the tech. told me that with the metal in the window film would block my radar, so I had to cut out a space next to the rear view mirror to place the radar. things worked out well, no problem at all.
Old Mar 26, 2003 | 01:51 PM
dr_gallup's Avatar
dr_gallup
https://my350z.com/forum/showthread....entine+install
https://my350z.com/forum/showthread....hlight=stealth
Old Mar 28, 2003 | 03:52 PM
Pedal Pusher's Avatar
Pedal Pusher
Default About the tinting........
I have mounted the detector above the mirror on my last two cars. They both had after market tinting at the top of the glass (5%) and I had no problems. I just got my Z tinted yesterday and plan to mount the detector in the same place again.
Old Mar 28, 2003 | 04:31 PM
AndyB's Avatar
AndyB
Default Tinting
Any window tint WILL decrease your laser sensitivity if you have a laser detector. If you see less light through it so will the detector.
As for radar, it depends on what the tint is made out of. Any metalic tint would interfere with radar detection for sure. Not sure about grey tints.
Old Mar 28, 2003 | 08:05 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I put mine just below the "dots" around the mirror. The suction cup on the right is stuck to the dots with a drop of crazy glue and the left one is just stuck to the glass. Works great and really not that visible. The red line drawn on the pic is the path I used to run the wires down to the fusebox. I used the cig. lighter fuse so it goes on and off with the key in the ignition.
Old Mar 29, 2003 | 06:02 AM
AndyB's Avatar
AndyB
Default Looks good
I think that is how I will mount my V1 when I get my Z.
Thanks
pinkie
Sep 16, 2022 09:55 AM
lazyZ
Nov 9, 2006 07:24 AM
flsunset
May 12, 2004 04:39 PM
Bonner928
Nov 12, 2002 06:08 AM
Samurai
Sep 23, 2002 06:32 AM
