Help!!! Z Down! Down!
Old Dec 26, 2006 | 07:32 AM
TTNosZ's Avatar
TTNosZ
Default Help!!! Z Down! Down!
ok so yesterday i installed my Throttlw body Spacer and Intake but my car wouldent rev over 2500 Rpms! so i took off The Intake n put the stock one back on and it reved just fine... where am i supose to put the plug in thingy for the intake sensor?!?!? on the aftermarket one?! thanks guys
Old Dec 26, 2006 | 08:05 AM
TTNosZ's Avatar
TTNosZ
anyone?or is it that obvious and maybe im just stupid?!
Old Dec 26, 2006 | 08:22 AM
Eazzy's Avatar
Eazzy
MAF sensor ?
Old Dec 26, 2006 | 08:24 AM
Eazzy's Avatar
Eazzy
And when u say intake, are u talking about a Pop Charger or a Typhoon ?
Old Dec 26, 2006 | 08:26 AM
TTNosZ's Avatar
TTNosZ
yeah i guess
Old Dec 26, 2006 | 08:27 AM
VO...'s Avatar
VO...
Administrator
Originally Posted by Eazzzzzzy
MAF sensor ?
I think that's what he's talking about. Same thing happened on my GF's camary.
Old Dec 26, 2006 | 08:30 AM
TTNosZ's Avatar
TTNosZ
so what should i do? throw away the intake?
Old Dec 26, 2006 | 08:31 AM
Eazzy's Avatar
Eazzy
OK ----On ur new "intake" ------Is it an aluminum tube that runs from the throttle body towards the front of the car to a new air filter ? Did the box it came in have a Name on it ---A manufacturer ?
Old Dec 26, 2006 | 08:32 AM
tylerdurden07's Avatar
tylerdurden07
Throttle body spacer? What kind of performance is that supposed to give you? do you mean Plenum spacer? As far as the intake goes, if you have a new pipe, you need to remove the stock MAF sensor and install it "PROPERLY" on the new intake. make sure don't put it on backwards, and plug it in. It should work just fine. make sure all of your clamps are secure as well....
Old Dec 26, 2006 | 08:35 AM
Eazzy's Avatar
Eazzy
If ur going to be that hasty about it , u probably should throw it away ---Other wise if u can slo down a little and explain the prob so we can understand it then we may be able to save u a trip to the Dumpster
Old Dec 26, 2006 | 08:36 AM
TTNosZ's Avatar
TTNosZ
hmmm... ok thanks guys
Old Dec 26, 2006 | 08:41 AM
ASTIG_Z's Avatar
ASTIG_Z
Your posts have NO details....how are we supposed to help you?
Old Dec 26, 2006 | 08:47 AM
IronMedic's Avatar
IronMedic
i bet he did not unbolt the maf sensor from the stock box and reused it.
