Power steering pump issues.....Help!!!
Does anyone know how to tell when a power steering pump has gone bad. i have an 03 with about 40K miles. At idle it feels like i don't have any power steering at all(this started yesterday), but when i rev a little the steering wheel turns freely, has my pump gone bad? also there's like a whistling noise coming from the pump, its not the fluid because its full, and the belt looks okay as well, what could be wrong with it? thanks
40,000 isnt an awful lot for a pump, but if it wasnt perfect, it could be going bad. Frankly in all yrs Iv replaced pumps, its been because they are whinning/howling really bad, or leaking real bad. Its the call of the mechanic thats working on it.
But the deal is --- A power steering pump is a Hydraulic pump. If it is not doing its job at low RPMs, then that is an indication of wear that has to be compensated for by spinning it faster. I kinda doubt it is a Rack and pinion prob ---They tend to just start leaking.
On Cars, U cant just plumb in a set of gages as I do with larger systems to check PSI.
Noise is the main sign and if u take a length of vacuum hose and put it in ur ear and press the other end to the pump, it will amplify that sound, and if u by chance have another Nissan around u can compare it with thats the way to go
im gonna take it to nissan on monday to see what they say, i hope they cover everything it needs, but i would like to know wtf happened to it! thanks for the help
CFAUVEL
Oct 1, 2015 03:20 PM
