oh crap... now whats wrong
Old Jan 3, 2007 | 10:57 AM
clipso 01's Avatar
clipso 01
Default oh crap... now whats wrong
Last night i stopped for gas on the way home from work. when i left the gas station i noticed that i didn't seem to have any power. the car kept bogging down and did not seem to want to accelerate. idle sounds horrible, and when i decelerated to pull into a parking lot the motor died. it started back up but still sounds like crap. under light acceleration it seems to hesitate, possibly sputter, i'm not sure if that would be the most appropriate term for it.
Acceleration in 6th gear at 50-60mph is almost non-existantat WOT.
backround:
i jwt popcharger and an apexi exhaust
1200 miles ago i replaced the tranmission and upgraded the clutch and flywheel
62,000 miles
2003 base z
no cel lights of any sort
Possibilities:
bad gas (i noticed it less than a mile after i left the gas station)
clogged fuel injectors
needs new plugs
i have only had the car for about 14,000 miles.
Any suggestions would be extremely appreciated
Old Jan 3, 2007 | 11:47 AM
first350's Avatar
first350
+1 on bad gas ... I just had a simlar problem, but I don't think it's the gas (I've been on the same gas tank for more than 100 miles)
good luck,
Peter
Old Jan 3, 2007 | 02:50 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
how long have the mods been on your car without problems?
my guess (other than the guesses stated) is dirty MAF sensor or you need to reset your ECU
Is the car in "limp mode" ? Any slip / VDC lights on the dash?
Old Jan 4, 2007 | 06:13 AM
MasterRacer's Avatar
MasterRacer
I would hate to think plugs/coilpacks?????? You sure somethings not misfiring ?
The Z uses Plat tipped plugs and go a LONG WAYS! check plugs 1st
Old Jan 4, 2007 | 08:21 AM
clipso 01's Avatar
clipso 01
thanks. i figure since i am going to take the time to take out the plugs i might as well replace them with aftermarket ones. what do you guys recomend and where is the best place to get them asap? i will be searching for this issue as well but you input is appreciated
thanks
Old Jan 4, 2007 | 05:40 PM
Jcolman's Avatar
Jcolman
I doubt that it's your plugs. Even a totally bad plug would still make your car run nearly normal.
Old Jan 4, 2007 | 08:50 PM
roast's Avatar
roast
+100 on bad gas....
Old Jan 5, 2007 | 04:44 AM
6society's Avatar
6society
+infinity+1 on bad gas. Take it to a garage, they can drain the tank and dispose of the bad gasoline.
Old Jan 5, 2007 | 05:44 AM
davidf's Avatar
davidf
Had you not just got gas I'd look elsewhere but it sounds like water in the fuel.
Old Jan 9, 2007 | 11:45 AM
clipso 01's Avatar
clipso 01
update: my car is running much better now, i think that it was just bad gas. i have filled up twice since then with93 octane and the car runnin just about normal
Old Jan 9, 2007 | 01:08 PM
Mazinger Z's Avatar
Mazinger Z
What did you use before?
Old Jan 10, 2007 | 05:48 AM
clipso 01's Avatar
clipso 01
92 octane but it was at a crapy gas statio in a little town i pass through on the way home from work. I think maybe it was just bad gas.
I always use premium.
Obadabot
Jun 18, 2023 11:31 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
