Need help ASAP!
Old Jan 10, 2007 | 08:38 AM
sleeperZ69's Avatar
sleeperZ69
Default Need help ASAP!
I just replaced my window motor successfully, but now the window seems to roll down too far and it ends up getting stuck at the bottom. My widow did this before I installed the new motor as well, so I know the motor isn't the problem. I was doing the whole window reset thing, and thats when it got stuck at the bottom. Is there any way I can adjust the regulator so the window doesn't go down as far?
I know this thread isn't in the right section, but I figured more people would see it this way, lol.
Thanks guy
Old Jan 10, 2007 | 01:10 PM
done12many2's Avatar
done12many2
Sounds like a malfuntion of the Limiter Switch
Old Jan 12, 2007 | 04:13 AM
sexygrandma's Avatar
sexygrandma
I've had the same issue many times over 3 years. Nissan just keeps resetting the limiter switch - won't replace the motor as tell me it's not broken. Can usually get the window up by holding on the "raise" button firmly even a few seconds after window goes up, then close door. If passenger side, must be done from driver's side after door is closed. Quite a pain here in the rainy/snowy Seattle!
etkms
Jun 19, 2022 06:30 PM
LunchBox20
Oct 20, 2015 10:22 PM
