Headlight cracks on the inside
Old Jan 15, 2007 | 05:12 AM
nofeardude87's Avatar
nofeardude87
Default Headlight cracks on the inside
My headlight has small cracking on the inside (I know this because when I touch the area on the outside with my finger it is smooth). Is there any way I can fix this? Would it be possible to open up the cover and sand down the cracking and then polish? Here's a pic of what it looks like:
Old Jan 21, 2007 | 05:23 AM
nofeardude87
any ideas?
Old Jan 23, 2007 | 02:37 PM
VO...'s Avatar
VO...
Administrator
i do not see the crack. Please describe where it is at.
Old Jan 23, 2007 | 02:44 PM
nofeardude87
look at the bottom right hand corner of the headlight. there will be several cracklines
Old Jan 23, 2007 | 02:50 PM
VO...'s Avatar
VO...
Administrator
I see what you mean now. Unfortunately, deep scratches are nothing that can be buffed out with ordinary plastic cleaner. I once had a professional re-surface my plastic headlights on a 9 year old car. they were stained really bad. He did a process where he sands down a layer of plastic, then begins to buff if out with an orbital buffer. Eventually he buffed it to a clear finish. It doesn't look like new, but it looked better than the yellow-ish film I had on the headlights. On headlights as new as those, you might have to either deal with it or pony up and get some new ones. New lights can be expensive though. Not sure if it's worth it. Good luck.
Old Jan 23, 2007 | 10:52 PM
nofeardude87
Thanks, so newer headlights have thinner plastic or something?
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
3vilbunny
Jul 18, 2017 05:10 PM
Twenty4
Jan 17, 2016 01:20 PM
JGee450
Sep 30, 2015 04:32 AM
