Clutch and Flywheel Problem
Old Feb 6, 2007 | 09:21 PM
tannee's Avatar
tannee
Default Clutch and Flywheel Problem
Guys,
Can you please help me out. I needed to change the clutch. Turns out that my 350z 2003 Roadster's flywheel moves so they cant machine it. So i decided to purchase a F1 RACING STAGE 1 Clutch FIDANZA Flywheel 350Z G35 VQ35. Once put it it's all good except it makes this huge annoying noise. The noise happens when im in low revs, and in too of a high gear ie no power. Eg. when coming out of a speed hump, and in 2nd gear, travelling about 30km an hour, and i accelerate, and the car doesnt have much power, the car makes a slight vibration as it would because it doesnt have enough power, but it makes this huge noise too. Is this noise normal for an aftermarket clutch and flywheel? After the car has enough power, the noise goes away and it's all sweet. The noise is kinda like a truck noise. Hard to describe it.
I really appreciate some feedback. Im so cut.
Thanks.
Old Feb 6, 2007 | 09:55 PM
plumpzz's Avatar
plumpzz
very normal.
Dmorrisjr350z's Avatar
Dmorrisjr350z
Im new to the 350z scene. However, when i upgraded my clutch and flywheel in my WRX there was a pretty "annoying", i didnt mind it, sound that would happen in 3rd gear mostly, but only without the gas on and at around 3,500-4,200 rpms. as soon as i hit the gas again the rattle would go away... it was completely normail in the WRX with that type of flywheel... i cant go out and say its the same thing happening in the Z.. but something to ease the mind a little maybe!
Dave
Old Feb 7, 2007 | 06:17 AM
DJMatrix1067's Avatar
DJMatrix1067
definitly happens in my car too. i upgraded from oem clutch and flywheel, to Nismo clutch, pressure plate and flywheel.
after i picked it up i got almost the exact same rattle as you. it goes away as i get more into the power curve. sounds like a rumble/ rattle of metal parts sort of. but ya not to worry
Old Feb 7, 2007 | 08:36 AM
MikeEwithTheZ's Avatar
MikeEwithTheZ
just a little chatter...nothing out of the ordinary
Old Feb 7, 2007 | 11:49 AM
tannee's Avatar
tannee
Thanks heaps guys...i really appreciate the feedback
I feel much better that it's a normal thing...
Maybe i should get an exhaust to cover up the noise! hehe
Old Feb 7, 2007 | 08:55 PM
Ztalker's Avatar
Ztalker
Originally Posted by tannee
Guys,
Can you please help me out. I needed to change the clutch. Turns out that my 350z 2003 Roadster's flywheel moves so they cant machine it. So i decided to purchase a F1 RACING STAGE 1 Clutch FIDANZA Flywheel 350Z G35 VQ35. Once put it it's all good except it makes this huge annoying noise. The noise is kinda like a truck noise. Hard to describe it.
Thanks.
Yeah.... the famous cement mixer noise, a common occurance with aftermarket lightweight flywheel/clutch combo in a Z.
Old Feb 8, 2007 | 12:44 PM
tannee's Avatar
tannee
so there's absolutely no solution to get rid of the noise?
thanks guys...
Old Feb 8, 2007 | 01:11 PM
MikeEwithTheZ
put in a stock clutch and flywheel
Old Feb 15, 2007 | 09:07 PM
Eazzy's Avatar
Eazzy
thanks guys...
No ---ur running a Hi Performance product, learn to live with the normal idiosyncracys or go back to stock
Old Feb 20, 2007 | 06:29 AM
the rainman's Avatar
the rainman
wow you sure told him, he was way out of line to ask that question.
Old Feb 20, 2007 | 07:16 AM
Eazzy's Avatar
Eazzy
I didnt mean to come across the way it may have been percieved, but a lot of guys dont relize that when modding, ur going to gain something and lose something. If u knock half the weight off the flywheel, there are going to be differences. Change ur shifting technics a little and just have fun
Old Feb 20, 2007 | 04:03 PM
tannee's Avatar
tannee
Ok...stupid question but if i keep the sports clutch, but get a sports flywheel that is the same weight as a stock, not a lightweight,...(if there is such thing) would the noise still be there?
Cheers.
Old Feb 20, 2007 | 04:52 PM
Eazzy's Avatar
Eazzy
I dont know that there is such a thing cuz there is no demand for it, but with more mass, u would have a quieter set up. The stock FW is a dampened assy.
I have switched out the dampened assys on Cummins Diesels and F350 Powerstroke Fords for comprable units not dampened just cuz of the simplicity and cost savings with no probs.But--Apples and Oranges kinda.
To bad ur not over here,I have a half dozen good,stock FWs that u could have. Is it THAT bad ???? Maybe just give it a little time---If it was installed properly, what u have is normal operation thats good in all intents and purposes cept for a normal clatter at times. If u change ur off the line shifting habits a little u can eliminate 80% of it
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
