Wheel Bounce When Cold
Old Feb 8, 2007 | 06:29 PM
venom2xk's Avatar
venom2xk
Default Wheel Bounce When Cold
Ok, it seems like this just started happening. do not know if its the cold weather or if i have a problem. When i pull out my Z at the beginning of driving especially on turns, it feels like my rear is hopping. This only happens for a couple minutes of driving and then stops. But when the Z is cold, it seems like the whole car is vibrating when im making small turns.
Any input greatly appreciated
Old Feb 8, 2007 | 08:10 PM
Depends on several factors such as temperature and how long the car has been sitting. In freezing weather after the car has been sitting for 8 hours plus, the tires have a flat spot. They are out of round. For the first several hundred feet, it feels like you are driving over big rocks: the rubber is trying to conform to a round shape. After they are warm, they will be round again.
Agressive driving on summer tires when the road surface is below freezing is not wise.
Old Feb 8, 2007 | 08:26 PM
drivenCSZ's Avatar
drivenCSZ
Originally Posted by davidv
Depends on several factors such as temperature and how long the car has been sitting. In freezing weather after the car has been sitting for 8 hours plus, the tires have a flat spot. They are out of round. For the first several hundred feet, it feels like you are driving over big rocks: the rubber trying to conform to a round shape. After they are warm, they will be round again.
Agressinve driving on summer tires when the road surface is below freezing is not wise.
+1 especially if you're rolling on stocks...they arent meant for cold temperatures and will skate and act funny in cold weather especially if they arent warmed up. Be careful, stock tires are not for driving in the cold and while they will do alright if its dry out in the cold, you're likely to kill yourslef if you encounter freezing temps+wetness
Old Feb 9, 2007 | 07:25 AM
imjdoggie's Avatar
imjdoggie
Thank you for asking this question man, I have had the same issue.
Old Feb 9, 2007 | 08:55 AM
venom2xk's Avatar
venom2xk
thanks a lot of the replies. yea winter and stocks is horrible i try to avoid driving as much as possible.
Old Feb 9, 2007 | 10:12 AM
joegengsta's Avatar
joegengsta
oh wow, phew.. when this first happened i was soooo nervous.. i got out in (-25 F windchill of minnesota) and checked all 4 wheels.. i thought i was dragging something or my axles were messed up.. drove a big longer and it went away.. hehe,
Old Feb 9, 2007 | 10:25 AM
Fluid1's Avatar
Fluid1
Your stock tires don't start performing well until they are at about 80*
If they don't hop, they will spin.
Obadabot
Jun 18, 2023 11:31 PM
