Oil pressure problem
Old Feb 18, 2007 | 08:51 AM
scratch137's Avatar
scratch137
Default Oil pressure problem
Ok well this may be just due to my noobish-ness but i live in FL and for the past 3 days it has been unusually cold ( in the 40s and 50s!!! OH NOES!! ) but i noticed that my oil pressure gauge is like all teh way to the right. PAST 120psi its just way over there. I changed my oil about 2500 miles ago w/ royal purple 10w30. Im wondering if anyone knows why this may be. Im hoping its just a busted gauge but i have no idea. The first day it started to get cold here i remember noticeing my pressure was around 90ish as i drove home late at night then i turned the car off and went to sleep so no more driving but then the next morning it was at/past the 120psi mark and has stayed there. It doesnt move for no one, but when i turn the car off it goes down.
Just like to say sorry if this was really hard to read cause im not exactly sure how to even explain whats going on. Im kinda just trying to say everything i know and let you pro's try to figure it out. SOOOO with that said, THANK YOU IN ADVANCE FOR ANY HELP YOU MAYBE GIVE
-Daniel
Old Feb 18, 2007 | 12:21 PM
Eazzy's Avatar
Eazzy
Replace ur Oil sending unit---40s isnt that cold and either way,it should drop within 5 minutes. OSU is 60.00 and is located next to the Oil filter. Very much TIY job ----Old screws out, new screws in ---It has a wire going to it. Dab a little Permatex Teflon Sealent on the threads
Old Feb 18, 2007 | 01:52 PM
scratch137's Avatar
scratch137
Is that covered under warrenty tho or no? Cause if its under warrenty then ill just take it in. And also, if that is the problem, is it an ergent like pressing issue or is it something minor.
Old Feb 18, 2007 | 03:52 PM
Eazzy's Avatar
Eazzy
I have no idea, but having ur gage working in a non FI engine is good to chk on how low ur press is rather than how high. With FI, both are important.
Point is ---Its not life threatening but just good mechanical maintenence.
Old Feb 19, 2007 | 08:21 AM
Ztalker's Avatar
Ztalker
i changed mine a couple of weeks ago for the same exact problem. You'll need a 24mm openend wrench to remove the old unit.
Old Feb 19, 2007 | 08:33 AM
Eazzy's Avatar
Eazzy
Im replacing one today and have replaced 4 prior
Old Feb 19, 2007 | 02:13 PM
scratch137's Avatar
scratch137
is this warrentyed? cause i rather nissan give me a free one then spend 60$ (im broke right now lawl)
Old Feb 19, 2007 | 02:20 PM
I1DER's Avatar
I1DER
Think. We don't know if you bought a used car, a new car, or how many miles you have on it. We should be asking you if it's under warrenty.
Old Feb 19, 2007 | 02:24 PM
scratch137's Avatar
scratch137
Ya my car is under warrenty still so now that ytou know what....is this repair under warrenty, and also i have had some tranny issues regarding grinding in 3rd and downshifting from 6 to 5th gear just randomly grinds do you know if something like that may also be under warrenty
Uriyo_
Sep 8, 2021 08:46 AM
