Window Glitch Fix Question
Old Mar 20, 2007 | 11:38 AM
JetBlack3's Avatar
JetBlack3
Default Window Glitch Fix Question
I know this is a big problem for a lot of z's where you use the auto-up function for the windows and then in comes back down 1/3. That happened to me but now my drivers side window doesn't work at all and is stuck down. I've heard that this problem can be fixed by re-setting the motor, but where is the motor? I pulled the door panel off, but do I need to take off that metal plate behind the panel to get to the motor? Any advice would be great, it's starting to rain and i need this window up badly.
Old Mar 20, 2007 | 03:55 PM
justinrlamb00's Avatar
justinrlamb00
yes, you have to take that plate off...but first try this GHETTO method I found works in a pinch. Shut your door, fairly hard...not SUPER hard...but enough to do something...while you are holding the UP button, that should roll the window up untill you can get in there and fix it.
Old Mar 20, 2007 | 03:59 PM
NA&CH's Avatar
NA&CH
Well hey mine just started to decide and go half way down when the car is off and locked
I need to get to Nissan and get this fixed and my tranny.
Old Mar 21, 2007 | 01:36 PM
JetBlack3's Avatar
JetBlack3
The last thing i wanna do is take it to the stealership, but after searching the forums for some answers it looks like that's the only way to perminently fix the problem
Old Mar 21, 2007 | 02:16 PM
Question
Isn't there a DIY motor replacement thread?
Old Mar 21, 2007 | 02:18 PM
You can also smack the door panel with your fist. My fist was black and blue until I finally replaced the motor.
07ZEKE
Aug 23, 2021 09:15 PM
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
Depravity
Oct 1, 2015 04:49 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
