Engine overheated...
Old Apr 11, 2003 | 11:19 AM
Static's Avatar
Static
Default Engine overheated...
I ran into an issue where my engine over heated... Can anyone let me know what might have been damaged in the process? The car runs completely fine, but I'm still worried.. anything in particular I should keep an eye out for in the future? I don't have this overheating issue anymore, just an FYI.
Old Apr 11, 2003 | 01:21 PM
imntcrzy's Avatar
imntcrzy
not to scare you but these are some possibilities of what could be damaged.
valves seals
head gasket
oil seals
bent valves
most likely everything is fine if you didn't drive while hot for too long. but a compression check couldn't hurt
Old Apr 11, 2003 | 01:27 PM
Static's Avatar
Static
Ok good to know... thanks much.. I'll probably try and do a compression check just to be sure.
Old Apr 11, 2003 | 01:32 PM
The Brickyard Rat's Avatar
The Brickyard Rat
What happaned to cause car to overheat?
Old Apr 11, 2003 | 01:55 PM
imntcrzy's Avatar
imntcrzy
my Z overheated after 2 months, due to the radiator blowing. Nissan replaced the radiator and said it was a fluke defective radiator.
Old Apr 11, 2003 | 02:21 PM
teh215's Avatar
teh215
What happened when the engine overheated? Did it start to run rough and stall? I hope that the Dealer did more than replace the radiator, like compression tests, check the coolant for oil, etc. An engine that overheats can have cronic problems if it did not shutdown immediately. Not to be the voice of doom but, I would defintely raise some concerns with the Dealer...
MAsSIVrOOM
Oct 20, 2023 10:50 AM
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
