fuel door / gas cap cover
Old Apr 21, 2007 | 09:41 AM
linuxbox's Avatar
linuxbox
Thumbs down fuel door / gas cap cover
i have a serious issue here. the frigg'n gas cap lid won't OPEN!!!! i push the button on interior to release the gas cap lid and NOTHING HAPPENS...i can hear the electrical click but it's like the door is stuck...i cannot even put gas in my damn car now...that's pitiful. it's a 2004 350Z.
anyone have any solution for this? obviously i cannot drive the car to the dealership because there isn't enough GAS to get there!
HELP!!
Old Apr 21, 2007 | 09:43 AM
Jay'Z's Avatar
Jay'Z
Try holding the button while someone pushes the door open..
Old Apr 21, 2007 | 09:53 AM
linuxbox's Avatar
linuxbox
Exclamation well...
shat! i have no one to do that so i'll have to find a way to tape the button pressed!!!!!!!!!!!!!!!
Old Apr 21, 2007 | 11:02 AM
fklentz's Avatar
fklentz
Have you chacked for a TSB?
http://www.nissanhelp.com/Ownership/.../NTB04-059.htm
Mine does the same, after pressing the button I use my key to flip it open.
Old Apr 21, 2007 | 11:12 AM
ZSpectrum's Avatar
ZSpectrum
same here very annoying.
Old Apr 21, 2007 | 11:26 AM
zstreet86's Avatar
zstreet86
sometimes i push the relase button but it doesnt pop out i have to stick in something like a pen to open it... but im sure youve tried that already...
Old Apr 21, 2007 | 12:44 PM
linuxbox's Avatar
linuxbox
Thumbs up hi
not sure what a tsb is but i checked out that link and yes i do hear a clicking noise. what's strange is that it just opened a while ago.....i didn't do anything special, just clicked it more and a few pulls/pushes on the lid; that's it. the link you sent makes it sound like there are replacement parts for this. is that right?
thanks!
Old Apr 21, 2007 | 02:11 PM
JMT's Avatar
JMT
thanks!
A "TSB" is a technical service bulletin that goes out when there is a consistent problem, but not enough to warrant a recall.
http://www.nissanhelp.com/Models/200...escription.htm
Here is a link to the 2004 area. Click on the bulletin tab. I had the fuel filling TSB done twice and each time I took a printout of the TSB from this website.
Old Apr 21, 2007 | 02:18 PM
linuxbox's Avatar
linuxbox
Thumbs up 10-4
thanks! my car is out of warranty so i guess i would have to get the parts myself and put it on...looks very simple though..just not sure where i can get those parts!!! thanks a bunch!
Old Apr 22, 2007 | 11:46 AM
billp's Avatar
billp
What about just putting a spongee piece of rubber "in there" to act as a "spring"?
Old Apr 23, 2007 | 10:54 AM
VO...'s Avatar
VO...
Administrator
The spring mechanism needs to be replaced. It's in the TSB.
+1 on having someone stick their fingernail in there to pull the door open while you press the button. I lucked out, my alarm remote's aux button is programmed to open the gas door. I can do it myself.
Old Apr 23, 2007 | 11:00 AM
psunner's Avatar
psunner
I have the same problem, even though i took it to nissan about 3 times so far. They tell me it's fixed but around a month later same problem. Now, i just used sticking my credit card in the corner and it usually pops the door.
Old Apr 23, 2007 | 01:00 PM
cubu's Avatar
cubu
i thought tsb's didn't require warranty
Old Apr 23, 2007 | 02:10 PM
VO...'s Avatar
VO...
Administrator
If I'm not mistaken, only recalls do not require warranties.
Old Apr 23, 2007 | 02:53 PM
cubu's Avatar
cubu
oh, well i guess i should take my car in to get all TSB's taken care of before my warranty is up
Old Apr 23, 2007 | 04:06 PM
03aeroZ's Avatar
03aeroZ
make sure your door didn' get caught on the piece of plastic that holds the cap to hte car....mine gets caught on that sometimes
Old Apr 23, 2007 | 04:12 PM
Black Duck's Avatar
Black Duck
Yep same problem and I've had it "fixed" already. Have to push the button several times to get it open.
Old Apr 24, 2007 | 06:26 AM
VO...'s Avatar
VO...
Administrator
Good idea....
Old Apr 24, 2007 | 01:26 PM
TheVoreHouse's Avatar
TheVoreHouse
Same here, just tap the button three times before you hop out of the car. Haven't had an issue...
Old Jul 14, 2009 | 01:21 AM
Venom8.1's Avatar
Venom8.1
there isn't a second button on interior to release the gas cap lid?
350Z_Al
Oct 29, 2020 07:44 PM
