Wrong RP gear oil!!!
Old Apr 22, 2007 | 12:53 AM
DRELOC's Avatar
DRELOC
Default Wrong RP gear oil!!!
I just got 30k service done at a local shop for $282 minus oil and sparkplugs change decent price IMO...i had Amsoil in my tranny and RP in diff but after the service i found out they put RoyalPurple Synchromax tranny fluid in my diff instead of Maxgear I asked them what happened they apologized for buying the wrong ones from Pepboys so they said to comeback later and redo the diff fluid only. So is it ok to leave the Synchromax in there until next service or change it out ASAP with Maxgear diff oil??? THANX
Old May 10, 2007 | 07:56 PM
n8vz's Avatar
n8vz
30K is too early to change sparkplug (unless you have some major mod).
Old May 11, 2007 | 04:01 AM
DavesZ#3's Avatar
DavesZ#3
I'd have them replace it now. From the RP website:
Synchromax is recommended for manual transmissions that specify an automatic transmission fluid or motor oil.
The 350Z doesn't use AT fluid.
Old May 11, 2007 | 04:41 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
The temps are much higher in the diff than in the transmission and you really need to get that fluid OUT of it immediately before it does any long term damage to the bearings, etc.
Old May 11, 2007 | 08:57 AM
LG_z33's Avatar
LG_z33
I would change it as soon as possible to avoid premature wear in the diff.
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
