Gauge cluster DEAD!! need help!
Old May 3, 2007 | 08:40 PM
sk26dett's Avatar
sk26dett
Default Gauge cluster DEAD!! need help!
I started my car today and all my gauges are dead, my whole gauge cluster wont turn on, and the 3 gauges in the middle are also out along with rear view mirror. What fuse(s) are all these things under? i want to go to nissan but i dont want them to be gay about electrical things i've changed (head unit, unichip).
thanks
Old May 3, 2007 | 09:41 PM
ohSIXz's Avatar
ohSIXz
dont have my manual on me... do you?
sorry im no help, but im not getting any on my repair thread either.
this website is all about flaming and rsx's.
Old May 4, 2007 | 07:28 PM
sk26dett's Avatar
sk26dett
bump! come on! someone, anyone!
Old May 4, 2007 | 07:36 PM
Netko350Z's Avatar
Netko350Z
Check owners manual
Old May 18, 2007 | 01:35 AM
ray427's Avatar
ray427
Before you so anything, pull fuses one by one and make sure their not blown.
Old May 18, 2007 | 03:47 AM
DavesZ#3's Avatar
DavesZ#3
Come on! Look at your owners manual!
In case you can't find it - the fuse panel is located behind the door on the drivers-side kick panel next to the dead pedal.
Old May 18, 2007 | 03:49 AM
DavesZ#3's Avatar
DavesZ#3
Interesting statement. When I looked at your post history, it seems as though your last 30 are nothing but off-topic stuff. You must not be seeking help that badly.
Old May 19, 2007 | 12:34 AM
rxkevin's Avatar
rxkevin
From all the threads I've read, most say it is Fuse#37. For me it seems like my Center Cluster, my radio, my rear defroster, and my rear cigarette lighter dont seem to work. I noted that the fuse was blown and replaced it, and checked it blew again, but it is fine. I am going to run down all the other fuses and see if any of them are blown but like I said, most would say check #37 (It is in the battery location, in front of the batter, labeled "Radio)
Old May 19, 2007 | 02:09 PM
DIGItonium's Avatar
DIGItonium
You've got some sort of short if the fuse blows again. Did you hook something up recently? Something melted and caused a short maybe.
Old May 22, 2007 | 01:42 PM
rxkevin's Avatar
rxkevin
Ok, I fixed my problem, not sure if the OP did as well.
I just checked all the fuses again. The Heated mirrors fuse and cigarette lighter were the cause of my problems. And I am ashamed to say I did not check the fuse on the back of my HU as well.
Old May 22, 2007 | 02:22 PM
VO...'s Avatar
VO...
Administrator
Should've of made it that easy. At least let em' look through all the fuses to find the blown one...
Old May 22, 2007 | 05:43 PM
sk26dett's Avatar
sk26dett
yea, thanks for the help guys, mine was just a blown fuse as well, but it was weird how many things where on that one fuse....My ac controls and head unit where on, but my whole gauge cluster, center gauges, and rear view mirror where dead, i wish i hadn't payed $50 bucks to get a fuse replaced, but when i checked the fuses myself the all looked okay.....o well problem solved
Old May 22, 2007 | 06:05 PM
rxkevin's Avatar
rxkevin
Oh I do all the work on my car myself. It was just a stupid mistake that I made on my part. I was changing out my center console for HIN Philly and forgot to disconnect the battery. Who knew that a small thing could blow 4 fuses.
Usually if a fuse is blown you can see the metal broken or blackend out. I would have fixed my car earlier but it has been raining for the last few days.
Old May 23, 2007 | 06:20 AM
VO...'s Avatar
VO...
Administrator
Got any pics from HIN, or has it not occurred yet? Probably the wrong section, but please post.
Old May 23, 2007 | 02:15 PM
rxkevin's Avatar
rxkevin
I have a few of my own car, which I don't think have been posted before.
I don't like going off topic, but here they are. Here is one I found of my car from another website. I can post more if you like but I will need to host them.
http://www.carandmodel.com/gallery/hin_hot_import_nights_philadelphia_pennsylvania_pa_20070512-cars/agl?full=1"]http://www.carandmodel.com/gallery/hin_hot_import_nights_philadelphia_pennsylvania_pa_20070512-cars/agl?full=1"]http://www.carandmodel.com/gallery/hin_hot_import_nights_philadelphia_pennsylvania_pa_20070512-cars/agl?full=1
Old May 19, 2012 | 03:57 AM
e30cabrio's Avatar
e30cabrio
I have a similar issue. That I am posting to this old thread should prove I searched. I have pulled EVERY fuse and no joy.
I have no gauge function. No tach, speedo, gas oil etc. All lights work and additionally the key in ignition warning buzzer is also gone.
Again. I have pulled every damn fuse and none are dead (and I went back and swapped them just to be certain.
The owners manual is a joke and the FSM is only slightly better.
Please help!
Old May 19, 2012 | 05:04 AM
e30cabrio's Avatar
e30cabrio
It gets odder.
I needed to get the car back together before it gets hot (already 85 at 5am) and after I did everything worked.
Self repairing electrical system?
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
Depravity
Oct 1, 2015 04:49 PM
