Code P0183 Fuel tank temp sensor...?????
Old May 5, 2007 | 01:04 PM
wat_it_IS's Avatar
wat_it_IS
Question Code P0183 Fuel tank temp sensor...?????
Has anyone has this code showed up on the scanner?
I just change the fuel tank cuz got a leak. But the engine service light came on, got it scanned then reset. Hopefully it won't return but if it does, does anybody has any idea?
Thanks
Old May 5, 2007 | 02:28 PM
DavesZ#3's Avatar
DavesZ#3
I'm going to go out on a limb and say that during the fuel tank replacment you either 1) damaged the fuel temperature sensor or 2) didn't reconnect the sensor.
Do you have a copy of the FSM, if so the EC section details how to debug and test the sensor.
Old May 7, 2007 | 07:53 AM
wat_it_IS's Avatar
wat_it_IS
Don't have the copy of FSM, need ur help and when replacing the tank everything was plugged and after reset it, no check engine light no longer comes on.
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
SharX59
Sep 27, 2015 09:23 AM
