battery leak?
Old May 10, 2007 | 09:03 PM
dragonbz99's Avatar
dragonbz99
Default battery leak?
On my other car my battery looks like it is leaking i have blue solid stuff all over the positive terminal and it seems like the bolt that attachs the positive cable to the terminal has been corroded by the acid, so it will be difficult to remove. does this mean i need to get a new battery? thanks
Old May 10, 2007 | 11:05 PM
Korki Buchek's Avatar
Korki Buchek
Corrosion is normal.
I'd suggest, though, if it is leaking.
Get some eye protection and gloves. Then mix a batch of battery acid 1:3 with cool water. Then spray the whole deal on a pair of jeans and wash it off after about 3 minutes.
DIY jean trendiness.
Old May 10, 2007 | 11:20 PM
CivicDelSlow's Avatar
CivicDelSlow
hahahaha
Ebay that ****
Old May 10, 2007 | 11:53 PM
dragonbz99's Avatar
dragonbz99
thanks for the replies. i read on some websites that you should wash it off with a baking soda solution. ill try it tomorrow
Old May 11, 2007 | 01:23 AM
CivicDelSlow
Honestly, I'd just get a new battery. Sounds like this one is giving you crap and if it's going to be in your Z then don't take any risks. Just get a new one. Before you know it, the acid is going to eat the plastic covering on your engine cover and eat plastic tubing and eventually make your engine bay look ghetto.
Old May 11, 2007 | 03:30 AM
trodis's Avatar
trodis
There is battery cleaner that will take it off. Just go down to the local car parts store. Spray and wipe!
Old May 11, 2007 | 03:46 AM
bailey bill's Avatar
bailey bill
1) Corrosion around the terminlas is NOT a symptom of a failing battery
2) Battery acid will NOT attack plastic. That's why bettery trays and boxes are made of plastic. And the container that the concentrated acid comes in is plastic.
3) Clean the area (with baking soda) and removing, cleaning, lubricating the tighteneing the clamps should take car the problem.
bill
Old May 11, 2007 | 09:43 PM
CivicDelSlow
bill
So, you are telling me that if this battery corrosion drips or splatters onto the dark grey plastic in your engine bay, that it will not leave a mark if left unattended for more than a few days?
I'm not calling you out, I am just suprised. I figured it would.
Old May 12, 2007 | 06:00 AM
Eazzy's Avatar
Eazzy
Clean up the mess including a new clamp----Do an ALT test and make sure its not exceeding 14.7 volts, if you lost a rectifier you may be over ampin and boiling the battery acid---Hence--fumes and surounding corrosion
Old May 12, 2007 | 06:03 AM
Eazzy's Avatar
Eazzy
And No ---Acid does not eat plastic---Acid is shipped in plastic bottles
Old Feb 6, 2009 | 08:00 AM
blackfairlady's Avatar
blackfairlady
I put a Battery Mat under each of my car batteries - 1 in the Z, and one in my DD. It is supposed to absorb corrosive battery acid that may leak out of an aging battery.
The one in the Z is the OE one with 37k miles. The car is an 04.
The one in the BMW is about 3 years old with 30k+ on it.
Each of the Battery Mats under the batteries have slight deposits of white powder on them around the perimeter of the battery's footprint.
As far as I'm concerned, these batteries are kind of new. I mean, not brand new, but they're definitely not old. The terminals and connectors are 100% clean, the powder is just showing up around the bottom.
Normal? Anything to worry about? I just plan on keeping both cars for a long, long time, so I am more concerned with any corrosion that may occur on the body of the car if battery acid leaks out.
Old Feb 6, 2009 | 02:33 PM
blackfairlady
bump
Old Feb 7, 2009 | 08:48 AM
blackfairlady
^ post 11 ^
Twenty4
Jan 17, 2016 01:20 PM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
