Transmission Warranty Question???
Old May 25, 2007 | 07:00 AM
Z-MIKE-GO's Avatar
Z-MIKE-GO
Default Transmission Warranty Question???
I have an 03' 350Z and was wondering if syncros are covered under the powertrain warranty. I am having grinding issues when going to 3rd gear above 3000 RPM. It seems to get worse with time. It sounds like I can't drive a stick shift...embarassing and loud!!! Please help with any info!!!
Old May 25, 2007 | 07:05 AM
ZCARBANDIT's Avatar
ZCARBANDIT
how many miles are on the car?
Old May 25, 2007 | 08:34 AM
DavesZ#3's Avatar
DavesZ#3
■ POWERTRAIN COVERAGE
• The Powertrain coverage period is 60 months or 60,000
miles, whichever comes first.
• This warranty covers any repairs needed to correct
defects in materials or workmanship.
• Powertrain coverage applies to components listed below,
supplied by Nissan except for those items listed
under the caption “WHAT IS NOT COVERED”.
ENGINE
Cylinder heads and block and all internal parts, rocker
covers and oil pan, valve train and front cover, timing chain
and tensioner, oil pump, water pump and fuel pump, fuel
injectors, intake and exhaust manifolds and supercharger,
flywheel, seals, and gaskets.
TRANSMISSION AND TRANSAXLE
Case and all internal parts, torque converter and converter
housing, automatic transmission control module, transfer
case and all internal parts, seals and gaskets, clutch cover
and housing, and electronic transmission controls.
DRIVETRAIN
Drive shafts, final drive housing and all internal parts,
propeller shafts, universal joints, bearings, seals and gaskets.
Old May 27, 2007 | 08:00 PM
Z-MIKE-GO's Avatar
Z-MIKE-GO
My Z has 44k miles on it.
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
