could gaskets...
Old Jun 28, 2007 | 11:20 PM
steppinrazor's Avatar
steppinrazor
Default could gaskets...
can a gasket leak cause this??
i have lost power in the last 4 days since i installed a new intake manifold, and i get this deep gargling sound when i press the gas while in gear, when it makes that sound i feel like ive lost power but as soon as the sound stops i get it back but if i keep the car in nutral and step on the gas it sounds just fine...
also, my gas milage has gone from an average of 19mpg down to 13mpg
Old Jun 29, 2007 | 06:06 AM
VO...'s Avatar
VO...
Administrator
What did you torque the bolts down to?
Old Jun 29, 2007 | 11:44 AM
steppinrazor
im not really sure... what happened was my buddy installed the kinetix v+ plenum in my car, it has these cork gaskets already attached to the part, well my friend also put my old gaskets on, then my friend who is a tech at nissan noticed that and said that is probably my problem
Old Jun 29, 2007 | 12:13 PM
VO...'s Avatar
VO...
Administrator
I believe the cork gasket replaces the original one. There would be no reason to have 2 gaskets....
Old Jun 29, 2007 | 04:15 PM
steppinrazor
your right, but i did not know that until now... so i have both on at the moment and my friend believes that is whats causing all the problems.. im just curious if others agree with him
Old Jun 30, 2007 | 06:18 PM
steppinrazor
also do you think by now there both damaged?
Old Jul 2, 2007 | 06:53 AM
VO...'s Avatar
VO...
Administrator
Nah, the bolts aren't torqued down enough to cause any real damage. Just inspect the new gasket for any abnormal indentions or tears. If it looks relatively flat/smooth, re-use it.
jakyle
Misc.
Mar 31, 2015 07:09 AM
alexml
Jun 24, 2014 08:24 AM
NissanTracker
Feb 6, 2012 08:39 PM
leeboyNY
Nov 15, 2005 10:08 AM
