3 Things Went Wrong after some Water and mild hit
Old Jul 3, 2007 | 04:14 PM
white350's Avatar
white350
Angry 3 Things Went Wrong after some Water and mild hit
The car did not flood or nething just went through some semi deep water and a lil moving around bumpy area made these things go wrong.
- ABS TCS Light is constantly on wont turn off. Took it to dealership said on the rear axle there is a pair of sensors that need to be replaced them to turn off light and make run correctly. true or false?
- Blower motor is gone from what nissan told me that it was smoking while testing. After the incident happen the a/c was working fine then cut out couple hours later and never blew again. Whenever the ac is turned on inside the car you can hear it crank up in the motor but nothing comes out of the vents. I checked fuses and both were blown that indicates blower on fuse panel. I change them again and it keeps blowing the fuses. I think its a short but Nissan say the blower motor needs to be replaced completely. If a short where to start or what could I do.
-HeadLight Got some moisture inside. The running light and turn signal works fine but the ballast or head light no longer works. Take it apart and get new ballast or do what nissan said just replace the entire headlight. I know the bumper needs to come off but to fix or take apart the headlight a difficult task?
They want to charge couple arms plus a leg to fix the problem. I was honest and got hit with ridiclious prices. I just want a little help.
Old Jul 5, 2007 | 07:41 PM
white350's Avatar
white350
Dam Nobody huh...
Old Jul 7, 2007 | 11:13 AM
white350's Avatar
white350
The blower needed to be replaced I changed it out so now the a.c is blastn real good, the light has been dried out and just needs the ballast. Monday I will have some answers
Obadabot
Jun 18, 2023 11:31 PM
_bit
Oct 2, 2015 07:49 AM
350z82
Oct 1, 2015 06:25 PM
