help please!!!!!!!!
Old Jul 8, 2007 | 05:26 PM
MPH350Z's Avatar
MPH350Z
Default help please!!!!!!!!
I have water in my floor board. it happens when i use my air conditioner the water is in my passenger side floor board what do i do thanks
Old Jul 8, 2007 | 05:56 PM
Kentetsu45's Avatar
Kentetsu45
Go to your Nissan and make them fix it
Old Jul 8, 2007 | 06:10 PM
coz's Avatar
coz
Agreed.
You probably should have a mechanic fix this one.
In the meantime air that car out as much as possible, it can start to mildew and smell very quickly, and once that starts you will be spending a lot of time getting that smell out.
coz
Old Jul 8, 2007 | 06:15 PM
Justin350z03's Avatar
Justin350z03
your a.c. drainage line is probably stopped up take is to nissan.
Old Jul 8, 2007 | 07:36 PM
Eazzy's Avatar
Eazzy
Or --look at a another Z and find out where the drain is. Depending on the design (Most are rubber hoses) clear it with whatever. I generally introduce a little bleach up there afterwords to kill the gunk
The reason I say another Z is because with his/her A/C running, you willl be able to locate it by the condensation drip, which is going on the ground as opposed to yours which is going in the car
Old Jul 8, 2007 | 07:50 PM
MPH350Z's Avatar
MPH350Z
thanks everyone for you help
Old Jul 9, 2007 | 01:30 PM
MPH350Z's Avatar
MPH350Z
i checked the tube that runs to the passenger side that goes to the floor board and out the car but its not stoped up is their anything else i can check or take it to the dealer thanks
Old Jul 9, 2007 | 04:45 PM
Eazzy's Avatar
Eazzy
All I can say from there, is if the liquid is slippery, it may be coolant from a bad heater core, or.........If you have had some work done that required penatation of the fire wall, you may be getting a leak from washing the car, or........if you have had rain, a drain plug on the floor pan is leaking
Old Jul 9, 2007 | 07:08 PM
MPH350Z's Avatar
MPH350Z
thanks EAZZZZZZY i will check that out
