oil sludge?
Old Jul 12, 2007 | 11:15 AM
nickZ33's Avatar
nickZ33
Default oil sludge?
I jus got my oil changed today and maybe a 1/2 quart came out. I know that cant be normal, so i was wondering if its all sludge? and the easiest way 2 fix it? any insight from you guru's would be greatly appreciated. Thx
~nick
Old Jul 12, 2007 | 11:17 AM
zand02max's Avatar
zand02max
holy ****. You have problems, serious problems! What year is your Z, mileage, is it under warranty?
Old Jul 12, 2007 | 11:23 AM
luvZcar's Avatar
luvZcar
sounds like you got some serious oil consumption man! you had only 1/2qt of oil in the car or was it a 1/2 qt of sludge+oil?anyways watch your oil consumption and take it back to the dealer
Old Jul 12, 2007 | 12:16 PM
nickZ33's Avatar
nickZ33
its an 03 with 41k miles and not under warranty as far as i know. it was str8 oil from what i could see, but the guy who was changing it under my car said the rest must be sludge and i should flush my engine, sound like a good idea? or should i be concerned with something more serious?
Old Jul 12, 2007 | 12:20 PM
350ZREDLINE's Avatar
350ZREDLINE
when was the last time you changed your oil before this? when he filled it back up how much oil did he have to put back in?
im pretty sure your engine would, uhh, be in bad shape if it only had 1/2 quart of oil in it.......
Old Jul 12, 2007 | 12:27 PM
tedroach's Avatar
tedroach
If you have an '03 with only 41k miles, you should still be under warranty. The standard is 5 year/65,000 mile, correct?
I would seriously get that checked out immediately.
Old Jul 12, 2007 | 12:31 PM
nickZ33's Avatar
nickZ33
i jus bought the car a week ago and the guy said it had regular oil changes , i did a carfax and it said it wasnt under warranty. ne other options then paying the stealership my life savings 2 check this out?
Old Jul 12, 2007 | 01:23 PM
Question
You saw 1/2 quart of oil come out of the motor right? And you measured it?
Old Jul 12, 2007 | 01:25 PM
fast kiwi's Avatar
fast kiwi
I take it you bought it from a privite party not dealership?? coz id be on my way back to the dealership if you had if not id find a good Nissan shop and prey they can help you
Old Jul 12, 2007 | 01:33 PM
nickZ33's Avatar
nickZ33
didnt measure it, it was an educated "guesstamite" and yea from a private party. but i had my mechanic look @ it, whos been doing work for my and my fam for almost 10 years and he said everything looked fine. although hes not a nissan specialist he does work with high end engines (mostly ferrari and porsche). i dunno now that the oil changed i dont have any oil pressure issues. Im just going 2 take it and have the engine flushed and get all the sludge and crap out. sound like a good move for the 1st step b4 i pay $$$$$$$ to have them inspect everything from head to toe
Old Jul 12, 2007 | 02:25 PM
350ZREDLINE
carfax might be talking about bumper to bumper warranty. You should have a 5year powertrain warranty, but I could be mistaken..
Old Jul 12, 2007 | 02:35 PM
nlsqba's Avatar
nlsqba
am I the only one to call it BS. looks like he was trying to SELL you engine flush.
did you see the oil?
Old Jul 12, 2007 | 02:40 PM
nickZ33's Avatar
nickZ33
yea i saw the oil that dripped out and it wasnt much at all. i knew i was low on oil but i didnt think that low. the oil pressure was always fine unless making a hard turn and rarely between shifting gears the light would pop on
Old Jul 12, 2007 | 02:43 PM
Tac-M's Avatar
Tac-M
+1 on BS. Go to a good shop and do a full service. Replace engine, trans, and diff oils. ASAP! Go with all synthetic as well. Drive it for 1k and do it again ! all 3 !
Old Jul 12, 2007 | 04:53 PM
350ZREDLINE
ya it has to be BS, maybe he drained the oil and then put the plug back on and then u watched him drain the rest. :P
he wanted to sell you something i bet
1quart of oil (or .5) would of made your car, well lets say you would know :P
Old Jul 12, 2007 | 05:32 PM
nickZ33's Avatar
nickZ33
thx for the info every1. im going to head to the stealership neway to have my recall done, and while im there ill have them check it out since i called (almost 4 numbers 2 get the right info ) and found out my powertrain warranty isnt up just yet
Old Jul 12, 2007 | 06:50 PM
Then you have little evidence to go on.
Check the oil level every 100 miles.
Old Oct 6, 2007 | 05:52 PM
JonsilvZ's Avatar
JonsilvZ
1/2 qt? you got to be kiddding me! At 54k miles there is no sludge if maintained. My 95 MB C36 AMG has 95k miles and did a oil change. All the 7.9qts came out. Well didnt measure but after the drain I put in the same qt # with Castrol syntec.
Old Oct 13, 2007 | 01:06 PM
Q45tech's Avatar
Q45tech
Do you have legal written documentation of every 7500 /180 day oil changes from 7500 to current 41k. That's 8-9-10 changes based on time not mileage from the date of first retail sale.
Nissan is tough and follows the warranty contract precisely!
Old Oct 13, 2007 | 01:19 PM
Al_s14's Avatar
Al_s14
If you're worried about sludge just take the cap off and look down with a light. ENgine flush good to remove soft sludge deposits but it wont get rid of the thick gunk, either way if your engine has oil consumption problems flush would not help anything. It is not uncommon for VQ engines 6 and 8 to consume little bit of oil. Especially if you wait long before oil changes expect to see a lot less oil then you put in.
PS i cant believe you saw your oil light flash and did not check oil level
