Window motor dead? Can't find the fuse...
Old Jul 16, 2007 | 02:30 PM
TenTilFour's Avatar
TenTilFour
Default Window motor dead? Can't find the fuse...
I consulted my owners manual and forum search in regards to where the location of the fusebox is but I can't seem to find it in my car... I'm going to assume that once i find the box I will also find the diagram that shows which fuse governs which electrical component as it's not listed in the manual.
I want to check the fuse though to make sure it's not something that simple before I take it to the stealership and have them install a new window motor.
Old Jul 16, 2007 | 02:37 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
it's prob. not a fuse. They are known to be bad and give out. Check and see if you qualify for the TSB on it or if you have warranty just take it in.
Old Jul 16, 2007 | 03:01 PM
TenTilFour's Avatar
TenTilFour
would it just work once second and die the next? I quite literally rolled it down, then tried to roll it back up with no avail...
Forgive me, but could you tell me what "TSB" means? I'm a newbie.
Old Jul 16, 2007 | 03:05 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Technical Service Bulletin. It's something that Nissan has acknowledged as a problem and issued a TSB to dealerships to let them know.
Old Jul 16, 2007 | 03:08 PM
TenTilFour's Avatar
TenTilFour
Oh okay cool, mine is a pretty early model (03)
edit:
Could someone please describe to me where the fuse box anyway, just so I can rule that out.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
