windows rolls down when key detaches from ignition...
It happened two days ago after some spirited driving. Both of my windows rolls down simultaneously when I pull out my keys. I reseted the battery hoping it would fix the problem but no luck. I am running out of ideas. I think the motors are fine as it still operates... any suggestions?
My 03 passenger window did something similar the other day. My key was still in the ignition. I clicked the switch to make the passenger side window automatically roll up. It went up half way then went back down. It did it twice. I eventually just held the switch up and it worked properly. Wierd
Ive been having the same problem with my 2003. I called the dealership and they said that something had to be reset on the inside of the door. Only they can do it, of course, and it should cost about an hour of labor, about $70. The cars have some mechanism inside that when the window senses something is caught it automatically rolls down. Its happened to me a few times, its just annoying.
