Need a good shop in the miami/ft lauderdale area
Old Jul 24, 2007 | 10:08 AM
Miami-Z's Avatar
Miami-Z
Default Need a good shop in the miami/ft lauderdale area
looking for a respectable shop to take my car to, to see if they can help me with my problem. vdc and slip light keep turning on then when i turn the car off it doesnt turn back on right away. sometimes takes about 5-10 min to crank over. Any input would be helpful. thanks
Old Jul 24, 2007 | 10:25 AM
HondaKiller's Avatar
HondaKiller
Change tire sizes recently? First thing is first, unplug your battery for an hour or more and plug it back in. See if problem persist. The dealership would be your best shop to troubleshoot a problem like that but more than likely is an easy fix that you would learn how to fix with a little research. Good luck.
Old Jul 24, 2007 | 10:35 AM
Miami-Z's Avatar
Miami-Z
yea upgraded to 19's about a few months ago. thanks, i'll try that. trying to avoid the dealership, plus i dont have warranty, its an 03
Old Jul 24, 2007 | 11:21 AM
HondaKiller
$80 to hook your computer up and run a diagnostics. The VDC is what is keeping your car from turning back over. The only thing i can think of the VDC acting up would be improper tire sizes. For a 19" (8.5 x 9.5) rim idealy you shoudl be running 275/35/19 rears and 255/40/19 fronts. Good way to tell if is your rims (which is probably it) will be to throw the stockies back on there and see if the problem continues. More than likely you have incorrect tire sizing therefore messing with the VDC which will kick in, stall you out, and prevent you from recranking the engine. Go to nissan, they will be able to help you even know it will cost you a pretty penny.
Old Jul 24, 2007 | 12:21 PM
Miami-Z's Avatar
Miami-Z
hey i appreciate it, ill give it a try.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
D_Rod
Sep 29, 2015 04:42 AM
samansharif
Sep 25, 2015 12:31 PM
