All rear brake lights wont come on.
Old Aug 24, 2007 | 05:13 PM
black350's Avatar
black350
Default All rear brake lights wont come on.
Like the title states, when depressing my brake pedal my friggin lights wont engage. I've already checked my stop lamp fuse and everything’s solid. My parking lamps are fine as well, now im just lookin around for my brake relay but i cant seem to find it. I'm going to jump back in there and see if I missed something. Any tips would be most appreciated, this is my daily driver, and ide hate to go to nissan for something simple.
Old Aug 24, 2007 | 06:07 PM
DavesZ#3's Avatar
DavesZ#3
Is it just the brake lights that are out or all rear lights (tail, turn signals)?
If the fuse is good, check the switch on the brake pedal assembly. The wiring is pretty simple - battery to fuse, fuse to switch, switch directly to all three brake lights.
Old Aug 24, 2007 | 07:36 PM
black350's Avatar
black350
I'm going to give the switch a try, the rear lights work (parking, turn reverse). Thanks for the help man, i dont like having my baby out of shape.
Old Aug 25, 2007 | 04:36 PM
Eazzy's Avatar
Eazzy
Just incase ---the fuse is under kick panel I believe the 4th one
Old Aug 25, 2007 | 04:44 PM
bizcotch's Avatar
bizcotch
Had the same problem which ended up being the brake switch. about 20bucks at autozone and easy to install. look under your dash at the top of the brake pedal, there you'll find the switch. 1. twist, remove 2. disconnect 3. replace with new one. Very easy!
Old Aug 28, 2007 | 12:38 PM
black350's Avatar
black350
Thanks guys for the help, it ended up being a loose cable...
Old Aug 29, 2007 | 05:11 PM
Jay'Z's Avatar
Jay'Z
I have a similar problem that just happened today.. ABS TCS SLIP lights are on.. Tail lights dont work and one head light works.. Only one turn signal works.. WTF gives?? Where are these fuses I checked the engine bay and those fuses looked fine.. Is there more fuses by the clutch pedal underneath that panel??
BTW im stuck in INDIANA because of this.. Because I cant drive at night now..
AbrasiveRaysive
Sep 20, 2021 02:29 PM
07ZEKE
Aug 23, 2021 09:15 PM
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
