window motor TSB available?
Old Sep 25, 2007 | 07:25 AM
thepostman's Avatar
thepostman
Question window motor TSB available?
Does anyone know if a TSB exists for the window motor issue? I've gone through most of the threads and searches and can't find anything.
Second, does anyone know if Nissan is using the same or an upgraded OEM window motor when it is at the dealer being "fixed" (which they will never acknowledge there was a problem)?
My driver side window wouldn't go back up, and went back up with the banging trick (2004/45k). I dont have time to mess with it and need it fixed asap.
Thanks.
Old Sep 25, 2007 | 09:07 AM
VO...'s Avatar
VO...
Administrator
I don't believe so..
Yes, it's an upgrade...
Old Sep 25, 2007 | 11:51 AM
thepostman's Avatar
thepostman
by any chance do u know what the model number should be for the upgraded window motor? thezstore.com has the part number as 30-2257 (driver side)
thx again.
Old Sep 25, 2007 | 12:34 PM
VO...'s Avatar
VO...
Administrator
I do not know it...
Old Sep 25, 2007 | 12:57 PM
ZCARBANDIT's Avatar
ZCARBANDIT
Old Sep 25, 2007 | 01:51 PM
VO...'s Avatar
VO...
Administrator
^^ The above instructions indicate that the window regular motor have to be reset if the "following work items have been performed". I'm assuming that resetting a regulator that is going bad will have no effect....
VO(making an observation)
Old Sep 25, 2007 | 02:01 PM
ZCARBANDIT's Avatar
ZCARBANDIT
yeah, if it is indeed bad there is no point in the reset.
Old Sep 25, 2007 | 02:04 PM
VO...'s Avatar
VO...
Administrator
It's still good info to know.
Fixxxercask
Nov 9, 2015 11:10 AM
