Repairing damage / scratches in the center console
Old Sep 26, 2007 | 07:19 PM
blofeld9999's Avatar
blofeld9999
Default Repairing damage / scratches in the center console
I noticed the other day that there's a pretty big scratch in my center console under the cubby (05 Z Roadster). I've attached a pic. See the white marks near the bottom left of the cubby.
Does anyone know how this can be touched up? I've seen suggestions to dab it with a sharpie which I tried, I'll have to see how it looks after a bit. But is there a paint or finisher that Nissan sells? Obviously replacing the entire center console is overkill - but there must be a way to make it look less ugly.
Thanks for any hints.
Attached Thumbnails Repairing damage / scratches in the center console-centerconsole.jpg
Old Sep 26, 2007 | 07:56 PM
Rob10_99's Avatar
Rob10_99
thats a textured surface isn't it?
plus that paint would be a hard match =/
Old Sep 26, 2007 | 08:03 PM
blofeld9999
Yeah, it's a dimpled surface. It actually wouldn't bother me terribly if there were no dimples in that small area. It's the discoloration that's probably more obvious.
Old Sep 22, 2010 | 03:51 PM
RubberDown's Avatar
RubberDown
I have similar scratches all over the center console and shift boot and A/C piece from general use. Maybe 3 years later someone has a good remedy?
Old Sep 25, 2010 | 10:11 AM
martin-'s Avatar
martin-
what i did to fix this bs was take everything out in the center, cover the all the gauges and boom sprayed with black gloss paint and it came out better than the stock ****.. got emmm
Old Sep 25, 2010 | 10:20 AM
Z Fo Sho's Avatar
Z Fo Sho
Tester's Matte Black Enamel. Its a dead match, did it to mine and the color match was perfect, texture wasn't noticeable
Old Oct 14, 2010 | 08:22 AM
ashtrojan2008's Avatar
ashtrojan2008
i used duplicolor vinyl & fabric flat black. Perfect match.
It's on a thread i saw somewhere a long time ago.. anyway just take it apart and spray it. You'll never see it.
ross
Old Aug 29, 2013 | 12:52 PM
Bearfan's Avatar
Bearfan
Anyone have a video thread on how to remove the center console so I can paint mine?
Old Aug 31, 2013 | 08:13 AM
Marrocco350z's Avatar
Marrocco350z
Got tired of mine and sanded down all the bumps painted and cleared it.
Old Aug 31, 2013 | 09:15 AM
dcains's Avatar
dcains
Had all my stuff hydrodipped, sorry not everything installed, yet. Just the door handles and A/C vents on the doors:
Here's the shop I'd recommend:
http://www.shawnaughtydesignz.com/index.html
Unless you have someone local, and can see their work, be careful sending parts off. I'm on my second attempt, after a rather bad experience with a sponsor on this site offering this service.
Old Aug 31, 2013 | 10:47 AM
DarkCreep's Avatar
DarkCreep
Hydro dip looks great!! I want to CF wrap my door handles and door armrests. Our door panels are so "boring".
OP just remove it, sand it and paint it. Mine isnt scratched up at all and I have an '03 (knock on wood) but if it starts scratching im going to paint it gloss black.
Old Sep 1, 2013 | 04:16 AM
Bearfan's Avatar
Bearfan
The gloss black looks nice. Any glare issues?
Old Sep 1, 2013 | 09:50 AM
DarkCreep's Avatar
DarkCreep
Good question, I didnt even think of that. I wonder how matte black would look as well.
Old Feb 25, 2014 | 11:46 PM
818dbz's Avatar
818dbz
any videos on how to take the center console/cubby apart???
Old Feb 25, 2014 | 11:55 PM
05nsn350z6's Avatar
05nsn350z6
Do a little research I the removal, I know when I did it I found it on here. Pull up and back on the shifter surround (remove shift **** first) then remove your cubby rubber mat.... Then just start taking out screws. Remember where they go that's all I did. The ones holding the radio bracket to the car are the hardest to get to....
Sand down and paint... That's what I did couldn't be happier, no glare issues either btw.
Old Feb 26, 2014 | 03:37 AM
travlee's Avatar
travlee
Master
gees..... pull up on the part around the shifter and you will see all the screws holding it in place....
Old Feb 26, 2014 | 09:41 AM
Painter6988's Avatar
Painter6988
Just started hydro dipping my center console.to me I think it's the cleanest way to go. painter6988/media/Mobile%20Uploads/image.jpg.html]Name:  image.jpg
Old Apr 12, 2014 | 08:11 PM
Pete5150's Avatar
Pete5150
How does that door come off? more importantly, how do you put it back on with the springs? What year door is that? I'm dealing with an '08. I want to take off the door and leather wrap it.
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
