HELP!! Car wont idle
Old Oct 7, 2007 | 03:16 PM
bradyh20's Avatar
bradyh20
Question HELP!! Car wont idle
I'm a total noob when it comes to tuning, but I went ahead and bought an AEM CAI and the Motordyne 5/16" plenum spacer. I installed both and went to start my engine. It fired up just fine, then started dropping RPMs until it finally died.
I ran through the ECU reset function, but wasn't sure that was working, so I disconnected the battery and pumped the brakes to reset the ECU that way.
I tried it again, and the same thing happened. I'm pretty sure that there aren't any intake leaks, but I can't figure out what the issue is.
Any ideas??
--Rob
Old Oct 7, 2007 | 03:33 PM
JonsilvZ's Avatar
JonsilvZ
Check all the connections and disconnect the battery for several hrs.
Old Oct 7, 2007 | 03:37 PM
bradyh20's Avatar
bradyh20
ok, I will...thanks.
I know that the MAF is installed an plugged in, but part of me wonders if I put it in the right way....I'll go check and then I'll leave it unplugged for a while.
Also, the strut tower bar doesn't seem to line up. Did anyone have problems with that?
Old Oct 7, 2007 | 03:40 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
check for air leaks in your plenum.
Old Oct 7, 2007 | 03:46 PM
bradyh20's Avatar
bradyh20
Whats the best way to check for those leaks?
Old Oct 7, 2007 | 04:25 PM
bizcotch's Avatar
bizcotch
reset the ecu. i usually have to repeat it several times before it idles right.
https://my350z.com/forum/showthread....osition+sensor
Old Oct 7, 2007 | 06:58 PM
bradyh20's Avatar
bradyh20
Thanks guys. Resetting the ECU helped. I hate to admit this, but the actual problem was I put the MAF in backwards... I guess that makes me a moron, but at least I figured it out.
--Rob
Thanks again for the advice!
Old Oct 10, 2007 | 04:41 PM
JonsilvZ's Avatar
JonsilvZ
I have the same spacer and the strut bar fits perfect. I think its your spacer.
Old Oct 10, 2007 | 04:43 PM
CEO350Z's Avatar
CEO350Z
That's bad juju
--Rob
hey, accidents happen but props for doing it yourself!!!
pslamp32
Feb 8, 2017 09:07 AM
OdesiTT
Sep 30, 2015 10:47 AM
05UltraYellow
Sep 24, 2015 05:41 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Darkspy
Sep 7, 2015 09:09 PM
