New WINDOW problem!
Old Oct 12, 2007 | 06:58 AM
playa6tnine's Avatar
playa6tnine
Default New WINDOW problem!
i noticed this problem after i installed new OEM seats. I dont think that affected it but who knows.
Both window motors are fairly new. Driver side window motor and module changed in March, Passenger's last year.
Problem 1: on the drivers side, when i open the door the window drops as its supposed to. But when i close the door the window does not go back up. I have to use the switch to bring it back up all the way. WTF???
Problem 2: on the passenger side window, sometimes it won't go down or it wont go up. This only happens when i use the switch. When I use the key fob to open them, it works. when i use the key and lock method, it closes. But when i use the window swtich, sometimes it doesnt work. WTF???
Old Oct 12, 2007 | 07:24 AM
kmg3773's Avatar
kmg3773
Key and lock method? what is that?
Old Oct 12, 2007 | 07:52 AM
playa6tnine
when both windows are down and you are outside of the car, you put the key in the keyhole, and turn and hold it to the right. your doors lock, and the windows go up after 2 seconds
Old Oct 16, 2007 | 03:14 PM
RandyK1's Avatar
RandyK1
How do you open and close the windows with the key fob? BTW thanks for the tip on using the key, I didnt know about that ether ...R...
Old Oct 16, 2007 | 03:16 PM
redman333's Avatar
redman333
You can only open the windows with the fob by holding the unlock button.
Old Oct 16, 2007 | 03:18 PM
RandyK1's Avatar
RandyK1
SWEET!! Thanks for the quick reply. ...R...
Old Jan 7, 2008 | 12:07 PM
playa6tnine
just for the record, incase anyone can ever relate to this issue, i found the problem.
The wire harness on the drivers side door jamb was loose (the rubber where the wires run from the car through to the door). this caused the connections of the "plug and socket" to be lose and unsecure. I had to by another grey securing lever which was like $3 from the dealer.
Old Mar 15, 2008 | 06:29 PM
BlueZ33's Avatar
BlueZ33
im having the exact same problem right now, if i use the key fob or the lock cylinder the passenger window works fine, but if i try to use the window switch on either side the passenger window will not work.
Old Mar 15, 2008 | 06:30 PM
BlueZ33's Avatar
BlueZ33
all i need to do is check the gray harness at the door jam
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
