lifespan of serpentine belt
Old Nov 1, 2007 | 07:40 AM
aggie05's Avatar
aggie05
Default lifespan of serpentine belt
How many miles / yrs are the factory belts good for? Cant find my manual.
How hard are they to replace, how long for the avg shade tree mechanic?
Thanks!
Old Nov 1, 2007 | 07:52 AM
HondaKiller's Avatar
HondaKiller
well you dont have a serpatine belt, you have a timing chain and it never needs replacement. If the chain needs replacement then it is likely you have a larger problem. Your altenator, Ac, Water pump belts need to be changed probably every 30k miles or 2-3 years.
Old Nov 1, 2007 | 08:05 AM
Ztalker's Avatar
Ztalker
Thanks!
shouldn't take more than 30 minutes to replace belts.
Old Nov 1, 2007 | 08:06 AM
Rog1206's Avatar
Rog1206
He must be talking about the drive belts. I changed mine at about 42k miles after it started to squeel and can easily be done on your own. I think there is a how to thread somewhere.
Old Nov 1, 2007 | 09:20 AM
DavesZ#3's Avatar
DavesZ#3
The Maintenance sched states 30K miles. Not hard to repalce but a little tricky getting the tension correct.
Old Nov 1, 2007 | 09:33 AM
jtabraham's Avatar
jtabraham
I replaced mine at 55k (previous owner never did) and the belt had clear signs of wear and mild cracking. The factory spec of replacing at 30k seems to be a good interval.
SonnyWu
Nov 24, 2015 08:19 PM
Vigman
Nov 17, 2015 04:34 AM
Fixxxercask
Nov 9, 2015 11:10 AM
Calinismo350z
Sep 14, 2015 04:04 PM
