Switchedc from Redline back to stock tranny fluid, notchiness gone.
Old May 30, 2003 | 07:36 PM
raceboy's Avatar
raceboy
Default Switchedc from Redline back to stock tranny fluid, notchiness gone.
My tranny was starting to get real notchy in 2nd and 3rd gear, especially when cold. It was filled with Redline lightweight Shockproof. I decided to see if going back to the stock fluid would make a difference so I drained and filled it this morning. Seems like the it's a lot better. Hmmmmm.
Old May 30, 2003 | 07:55 PM
elektrik_juggernaut's Avatar
elektrik_juggernaut
did you have grinds before you went to Redline?
Old May 30, 2003 | 07:59 PM
raceboy's Avatar
raceboy
I had no grinds, just some resistance going into gear. The Redline cured the resistance, but then the grinds cropped up.
Old May 30, 2003 | 09:27 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Isn't MT-90 the recommended Redline fluid for the 350Z?
Old May 31, 2003 | 05:17 AM
hwj's Avatar
hwj
Red Line's web site doesn't state whether the "Shockproof" is a GL4 or GL5, and it seems it's recommended for racing usage.
Once I have my new trans installed, I have 4 quarts of Red Line MTL/MT-90 mix ready to go in once I'm sure the "2nd to 3rd cold oil shift grind" is cured.
Did Red Line recommend the "Shockproof"?
Old May 31, 2003 | 05:43 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
no, they recommend mix of MTL and MT-90.
From raceboy's experience, I wonder if I should switch back to factory tranny oil? I feel the notchness too on 2nd, and 3rd..
Old May 31, 2003 | 07:32 AM
droideka's Avatar
droideka
I did the MT-90/MT-L mix a few weeks back. I feel that the shifting is a helluva lot smoother now than it was. Very "liquid" feel to it. Now, I believe that the notchiness is a function of the gate itself, as in you have to make that slide from gear-to-gear perfect or you get hung up on the gate.
An additional benefit was that my flywheel/bearing chatter in neutral with clutch out was reduced significantly.
Old May 31, 2003 | 08:03 PM
raceboy's Avatar
raceboy
I'm positive it's not the gate. It's a feeling of gears grinding slightly before they engage.
Old May 31, 2003 | 08:52 PM
droideka's Avatar
droideka
OK. I don't have that problem.
Old Sep 25, 2003 | 12:15 AM
SnoopyZ's Avatar
SnoopyZ
I have this problem and I am on stock fluids... I was going to try "redline" tranny fluid. What should I do?
Old Sep 25, 2003 | 06:14 AM
dimitri's Avatar
dimitri
hello fellas i have a 2004 track i just bought s.s. And i feel i have that notchiness felling but i just cant expalin sometimes it feels smoother then other times i still running original fluild i have 100 miles on the car but it kinda feels that u have to be precise when shifting no room for error is that normal oir just the way this transmission is built i thought of calling dealer or just practice to be more precise before i bother taking to dealer or just wait to see if a recall happens .....just like on my 2000 honda accord they upe my warrnt to 75k and 7 yrs because they having issues with that transmission...thanks please shed some light
Old Sep 25, 2003 | 08:02 AM
hwj's Avatar
hwj
Since mid-July the new trans. HAS NOT had any 2nd to 3rd upshift when cold grinding on the stock trans oil.
I'm waiting for the cooler weather to get here in October then that will be the true test. If no problems arise by November, I'll put in the RedLine mix I've had hanging around for the past 5 months.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Dymsi
Sep 29, 2015 11:32 AM
