VDC on/off, e-brake, and Slip indicators always on
Old Jan 4, 2008 | 08:20 PM
Corradoslc7's Avatar
Corradoslc7
Originally Posted by DmanG281
^what he said
I had the same problem and checked my front brake pads and they were almost down to the backing plate. After i changed the pads all lights were off and I was good to go.
I think that your problem was also due to low fluid. The front caliper pistons were pushed so far out that the fluid in the master cylinder dropped far enough to turn on your TCS,Slip and ABS lights. When you installed new thicker pads and pushed the piston back into the caliper the fluid level went back to the correct level.
To the op your problem is similiar becuase as you clutch wore, the slave cylinder had to be pushed farther to compensate for less clutch disk material. This caused the fluid level to drop and turn on the VDC/ABS/Slip lights.
Old Feb 2, 2008 | 09:22 PM
dnguyent's Avatar
dnguyent
Check this thread too:
https://my350z.com/forum/autocross-road/300169-abs-control-unit-malfunctioning.html
I had the same symptoms. It turned out, for me, that the ABS Module shorted out. See thread for details...
Old Feb 8, 2008 | 10:32 PM
rrmedicx's Avatar
rrmedicx
The same thing happens to me when my brakes are low. I would agree that the car is trying to tell you something is wrong. For me it happens once a year, which is about how long my brakes usually last. Once replaced, the lights go off immediately. Good Luck.
Old Feb 9, 2008 | 04:55 PM
Corradoslc7
How many miles do you put on your Z a year to require new pads annually.
Old Feb 9, 2008 | 05:52 PM
rrmedicx's Avatar
rrmedicx
I put between 18-20K each year in NYC. Lots of red lights.
Old Feb 9, 2008 | 07:13 PM
wizurd's Avatar
wizurd
I'm having the same problem but my pads are fine. Could this be due to near-bald tires? I just noticed yesterday that my rear tires are terribly low on tread.
Also, if I disconnect the battery for 15 minutes and reconnect it, the ABS light won't come on until I start driving but everything else is off from after ignition.
Old Feb 10, 2008 | 05:10 PM
Corradoslc7
Wizurd, did you check your brake fluid level?
loudtoyz
Apr 6, 2023 04:52 AM
aarrgghh
May 1, 2022 11:04 AM
Depravity
Oct 1, 2015 04:49 PM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
hardwood66
Sep 8, 2015 04:31 AM
