rattle/squeal at 2500rpm on acceleration
Old Nov 23, 2007 | 02:17 PM
ZedNewbie's Avatar
ZedNewbie
Default rattle/squeal at 2500rpm on acceleration
I took the car into the dealership (Power Nissan Torrance) for diagnosis of this noise at 2500rpm when accelerating, and they found nothing. I got the usual dealer runaround when trying to get it fixed.
The sound started a few months ago, and it is quite annoying since 2500rpm is cruising speed (65mph) on the highway in 4th gear. The noise is constant at that rpm range.
I am pretty sure it is not the belts or alternator bearings making the noise. It might be coming from the air intake, but have no ideas on how to fix it.
I searched the other threads but couldn't find anything similar, so any help would be appreciated.
Old Nov 23, 2007 | 02:38 PM
tresani's Avatar
tresani
Out of curiousity, do you have an aftermarket cold air intake? or JWT popcharger? That can cause a whistle around that rpm (it does on mine)
Old Nov 23, 2007 | 02:39 PM
ZedNewbie's Avatar
ZedNewbie
Yep, I do. It didn't make that noise before, though. Maybe cleaning it will help, which I am set to do tomorrow. If it clears up the noise, I'll post here and let you know.
Old Nov 23, 2007 | 05:01 PM
99lspwr's Avatar
99lspwr
There is alot of resonating through the y-pipe at this rpm..If yours is a little loose inside it can make a vibrating/humming type sound..
Old Nov 24, 2007 | 06:22 PM
ZedNewbie's Avatar
ZedNewbie
Well, I just cleaned and oiled my popcharger and the sound is still there. I'll have my suspension and exhaust system checked next. Thanks for your input.
etkms
Jun 19, 2022 06:30 PM
pslamp32
Feb 8, 2017 09:07 AM
AbyteZero
Sep 22, 2015 09:17 AM
ti837
Sep 22, 2015 07:46 AM
