I Drilled HOLES in my GAS TANK!!
Old Nov 26, 2007 | 03:20 PM
stylett9's Avatar
stylett9
better get back in there and make sure fuel isn't leaking all over into places you dont know about.
Old Nov 26, 2007 | 04:23 PM
Key Of Z's Avatar
Key Of Z
Quote:
Originally Posted by ToXiC
haha oh man that sucks. you've probably been inhaling gas fumes for the past 2 years
That would explain alot
Old Nov 26, 2007 | 05:21 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
wow! you did that 2 years ago!??!!? and you didn't notice that?!?!
go go go spend money!!
for your life now!
Old Nov 26, 2007 | 05:26 PM
michaeljr6's Avatar
michaeljr6
buy a new car
Old Nov 26, 2007 | 05:30 PM
blasian's Avatar
blasian
Wonder if he had any Sony Xplod equipment.
Ghost 350z's Avatar
Ghost 350z
pm Old School, some nutbutter should take care of that
Old Nov 26, 2007 | 06:17 PM
failsafe306's Avatar
failsafe306
Just weld the holes up.....KIDDING.
Take it to the dealer, tell them you're not that bright, and take the multi-hundred dollar repair bill for a new tank up the *** and chalk it up to a learning experience.
Old Nov 26, 2007 | 06:19 PM
350ZTheStandard's Avatar
350ZTheStandard
MY amps are mounted behind the seats, but not on the floor, mounted vertical. I will checking this out later tonite, lerning from your mistake
Old Nov 26, 2007 | 06:40 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Funny thing is, I know I've seen a thread like this years ago...
I agree with those saying get it replaced for real at the dealer.
Old Nov 26, 2007 | 06:51 PM
Mazinger Z's Avatar
Mazinger Z
Don't worry about it, you're good.
Old Nov 26, 2007 | 07:00 PM
Pretzle's Avatar
Pretzle
crazy times!!
Old Nov 26, 2007 | 10:27 PM
l-con1's Avatar
l-con1
Did you graduate from UTI? kidding i had to do it.
Take it out and seal it! drop sub frame then 4 nuts holding it up if i remember correctly. once sealed you shouldnt have any problems. not that easy but once you remove everything on the way you should be able to drop the tank far enough to access the holes. can be done in about a day!
Old Nov 26, 2007 | 10:31 PM
bamyi's Avatar
bamyi
+1 I remember someone else haveing the exact same problem. I'm pretty sure there are also alot of ppl out there that have the same problem but just don't know it yet.
along with the other suggestions.....mine is to drive with the windows down untill you get it fix.
Old Nov 26, 2007 | 11:10 PM
jmasi's Avatar
jmasi
a stereo shop did the same thing to my civic back in the day..i just had the dealership install a new tank for me.. it is going to run you about $600+ easilycause my civic was about $400
Old Nov 27, 2007 | 12:44 PM
ryan21's Avatar
ryan21
Ok thanks for all the advice, I think I will try to take the tank out myself and fix it, As for the current condintion, Ive put the screws that were holding my amps back into there respective holes, and this has solved the problem, of having any smell of the gas vapors anywhere, also after clearing the SES code the light has not come back on, but I am definetly going to fix the tank anyway, so the next guy with my car doesnt remove the screws and light up a cigarette.
Also one other question, about the fuel hose recall for the 2003 Z's when they fix that problem do they remove the tank, if so I wonder if I could get them to patch it up while it was out or exposed, just an idea to save money, as I am a poor college student
Old Nov 27, 2007 | 12:58 PM
rcdash's Avatar
rcdash
Let the dealer do it. See if you can work something out with the recall like you mentioned. My understanding is that a lot of parts need to come out to get this done.
Don't try to patch the holes with the tank in place. You'd need to cut metal and the sparks would cause a disaster.
Old Nov 27, 2007 | 01:08 PM
RedBullRR's Avatar
RedBullRR
WoW
Old Nov 27, 2007 | 01:29 PM
  #38
Spork's Avatar
Spork
One way to fix this...
MIG welding
  #39
ajcool2's Avatar
ajcool2
Originally Posted by RedBullRR
WoW
+1
Old Nov 28, 2007 | 07:49 AM
  #40
jetnoirZ's Avatar
jetnoirZ
