Redline Fluids
Old Nov 29, 2007 | 09:44 AM
Mr_Kebo's Avatar
Mr_Kebo
Default Redline Fluids
I orderd 2 quarts of MTL 70w80 and 2 quarts of MT-90 75W90. Searcing this topic isnt as easy as some others seeing as we have a color called redline. I think i remeber reading somewhere i needed to order both of those and mix them to get the correct weight for the tranny. Is this true or was i just dreaming.
Old Nov 29, 2007 | 09:48 AM
RandomHer0's Avatar
RandomHer0
Nissan calls for 75W-85 oil. Many owners suggest using Redline fluid, but the do not offer the exact oil weight so this requires a mix if using Redline fluid (2 quarts each):
Redline MTL: 70W-80
Redline MT-90: 75W-90
http://www.*********.com/zwiki/Manua...id_Replacement
Edit: I guess these 2 sites don't like to play together?
Old Nov 29, 2007 | 09:51 AM
Mr_Kebo's Avatar
Mr_Kebo
Hmm guess not. I figured the site out tho
Old Dec 3, 2007 | 05:45 AM
Eazzy's Avatar
Eazzy
https://my350z.com/forum/showthread....=1#post3698152
Old Dec 10, 2007 | 09:55 PM
Seamaster's Avatar
Seamaster
I will put redline 75w-90 when next oil change, just talked to a nissan tech, they said just fine. But don't mix different weight oil.
Old Dec 15, 2007 | 06:38 AM
Exiled Lakai's Avatar
Exiled Lakai
Sorry to hijack but how many qts of MT 90 does the rear end take?
Old Dec 15, 2007 | 07:03 AM
Exiled Lakai
nevermind i just bought two gallons for the tranny and the rear end. if thats not enough
Old Dec 15, 2007 | 02:14 PM
niznos's Avatar
niznos
I ended up mixing MTL and MT90 because of what I read too, but I think if I had it to do over again, I'd just go with straight MT90. The Redline oil site actually lists Nissan under the product description for MT90. You should be fine either way though.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
Ace2347
Sep 22, 2015 03:12 AM
