350Z Leaking ! ! !
Old Dec 3, 2007 | 09:02 PM
aireq's Avatar
aireq
Default 350Z Leaking ! ! !
So a couple weeks ago I noticed that it was wet under my drivers seat. I park my car outside so I thought that I might have left my window cracked open and it never got a chance to dry out. Last weekend for thanksgiving I parked it in my parents garage with some fans on it to dry it out. It didn't rain since then until this weekend. Now the water is back. The depression under the drivers seat is completely soaked, and the carpet under the floor matt is damp. It's not obvious at all where it's comming from. And yes my window actuators seem to work just fine on both sides.
Anyone have any idea where this water could be comming from?
Eric
Old Dec 3, 2007 | 09:22 PM
SeannMikee's Avatar
SeannMikee
Your pants when u get nervous? lol jk i really have no clue
Old Dec 3, 2007 | 09:26 PM
fairladyinit's Avatar
fairladyinit
Is there smell in the liquid at all? If not check your drains to make sure they're locked. Look in your manual for the drains.
Here's an example from another site.
In the rear passenger side fender area there are two drain hoses, one from the antenna motor and one from the sunroof. In the bottom of the fender there is a small pot-metal y-shaped piece that both hoses plug into and then that y-piece is shoved through a rubber gasket to the outside world. This y-shaped piece rusts and may cause blockage and overflowing. The cause of my antenna motor breaking was probably caused by a back-up of water. When I pulled the hose and the y-shaped piece, the hose was completely blocked and after dislodging the blockage a lot of water came pouring out. Another thing to point out too, is that because this y-piece sits in the only exit from the fender, any water from overflow will sit in the bottom of the fender without a way to exit. I had a small puddle with some debris down in the bottom of the fender. After I took out the plug in the bottom, a good amount of water came pouring out. Rust anyone? Tomorrow, I'm going to check the driver side area and see if that side may have the same issue.
Old Dec 3, 2007 | 11:15 PM
FastZ33's Avatar
FastZ33
diaper??
Old Dec 3, 2007 | 11:37 PM
aireq's Avatar
aireq
No there is no smell in the liquid. And it only happens when it rains so I know it's a leak from the outside.
Ummm? My car has an antenna motor? Or did you just mean that as an example.
Eric
Old Dec 4, 2007 | 02:44 AM
aireq's Avatar
aireq
ok I pulled up a bunch of the carpet under the drivers seat and there is about a half inch of water all under the floor matt area, and under the back of the seat. I felt all over but it wasn't obvious at all where the leak was comming from.
Is there some kind of drain that I can open to get this water out? Anyone have any idea where this could be comming from?
Eric
Old Dec 4, 2007 | 03:13 AM
shadykilla717's Avatar
shadykilla717
Bring it to Nissan or a shop??
Old Dec 4, 2007 | 06:59 AM
You know that this is a serious problem. A wet floor means corrosion and rust. Very difficult to fix.
I suggest that you visit mechanic who is familiar with the 350Z. Troubleshooting water leaks is time consuming and expensive. I do not believe that there is an inexpensive alternative.
Note: Drain plugs are outlined in the service manual.
Old Dec 4, 2007 | 07:59 AM
fairladyinit
yes look in your service manual for the drain plug. Be prepared for a lot of water to come gushing out.
Old Dec 4, 2007 | 08:21 AM
teh215's Avatar
teh215
I believe that there are drains in the cowl area at the base of the windshield. Pop the hood and look around at the plastic channels at the base of the windshield and see if there is alot of debris where the wiper arm comes through, etc. g/l
Old Dec 4, 2007 | 02:44 PM
JonsilvZ's Avatar
JonsilvZ
Blow the clogged drain holes with a high pressure nozzle.
Old Dec 5, 2007 | 08:38 AM
skwid's Avatar
skwid
that's really strange on the Z. I've never heard of one leaking like that. Did you have anything recently replaced? Windshield? Window?
Check the hatch seals, etc... Water can get in anywhere.
Old Dec 5, 2007 | 07:18 PM
aireq's Avatar
aireq
There is a lot of debris in the area where the the wiper arm comes through.
The service Manual? I have a Factory service manual (well a pdf of it), and the owners manual. I'm not sure where to look in either for anything about the drain plugs.
Old Dec 5, 2007 | 07:24 PM
aireq's Avatar
aireq
I searched the factory service manual and the only instance of "drain plug" i could find had to do with drive train drain plugs (oil pan, transmision, block etc...)
Is it possibly called something else?
Eric
Old Dec 5, 2007 | 07:56 PM
Corradoslc7's Avatar
Corradoslc7
Stop parking your car under trees, the leaves get in the drains and prevent water from draining. The water backs up and finds its way into the car.
Old Dec 5, 2007 | 08:21 PM
aireq's Avatar
aireq
Where are the drains?
Eric
Old Dec 5, 2007 | 08:25 PM
jaspendlove's Avatar
jaspendlove
good luck. keep us posted
Old Dec 5, 2007 | 10:33 PM
aireq's Avatar
aireq
What drains? Where are the drains?
Eric
Old Dec 5, 2007 | 10:35 PM
350ZTheStandard's Avatar
350ZTheStandard
Seems everything in Seattle is flooding this past week, I would check the drains in the doors and also the rubber seals on the bottoms of each door. Also is there water buildup under the passengers side also, have you checked???
And lastly do you drink bottled water in your car and maybe the bottle rolled under the drivers seat and spilled.
Old Dec 5, 2007 | 11:42 PM
aireq's Avatar
aireq
There is no water in the passenger side. I pulled of the the plastic cover that usualy cover up the area where the brake master cylinder is. It looks like someone drilled a hole through my firewall to, I"m assuming, run a cable.
So i'm going to put a plug in that and try to suck out all the water and see if it happens again.
Eric
