Clutch pedal making noise
Old Dec 12, 2007 | 03:44 PM
Robby18's Avatar
Robby18
Exclamation Clutch pedal making noise
yea so lately when i press the clutch pedal it makes a clicking/popping sound and is now sitting lower then my brake pedal.. it sits about a half inch lower or maybe more..
yes it has an after market clutch in it.
last night i went to get in my car and i TRIED putting it in reverse but it wouldn't let me..as if the clutch wasn't being pushed in..
so i asked around today and my grandfather was saying it sounds like the master cylinder or slave cylinder is "popping." "getting stuck and unsticking itself"
well i looked around on the web today and found that u can adjust the height of ur pedal by adjusting some of the stuff on the clutch assembly and even adjust the rod for the master cylinder..
i tried it and it has helped for now...but i want to know if maybe my master cylinder is going out or maybe its something completely different. what do u guys think?.
Old Dec 12, 2007 | 03:49 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
sounds like a miss adjusted clutch and as for the sound could be normal but i doubt it as for the MC or the slave cyl going out i havent seen one yet but you could be the first and what kind of clutch is it?
Old Dec 12, 2007 | 03:55 PM
Robby18's Avatar
Robby18
its an ACT clutch..
the sound is coming from where the clutch assembly connects to the firewall..and like i said it makes a strange popping sound.. i really have no idea what to think lol...and of course its no longer under warranty and Nissan is gonna charge an A** raping amount probably
Old Dec 12, 2007 | 03:59 PM
SGP_Racing's Avatar
SGP_Racing
Default Most likely
a bad Master Cylinder. If it worked well after install, then most likely that is your problem. We have seen a few here with high Pressure Plates go out after 5,000 miles or so... ACT has a pretty high pressure plate. It could also just be a leak, check your fluid first..
Mark
Old Dec 12, 2007 | 04:04 PM
Robby18's Avatar
Robby18
yea its been about 6k miles since the install..
i checked the fluid and lines no leaks and the fluid is maxed out..
if the MC is the case...should i change to braided steel lines? and do a slave change out too?
Old Dec 13, 2007 | 06:32 AM
RedBullRR's Avatar
RedBullRR
I would def do a SS line for that high pressure plate. I noticed a huge difference with the SS line.
Old Dec 14, 2007 | 08:03 AM
bommart's Avatar
bommart
+1
sherm
Apr 11, 2020 05:21 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
samansharif
Sep 25, 2015 12:31 PM
