Gas Door?
Old Dec 29, 2007 | 08:34 AM
NewZ84's Avatar
NewZ84
Default Gas Door?
is there a trick or something when trying to put in gas?!! i'm test driving an 06 for the weekend and the gas tank doesn't open when i push the button to open it. i can hear it trying, but it just doesn't open. how do i do it??
Old Dec 29, 2007 | 09:01 AM
Tim@WestCovinaNissan's Avatar
The door is probably out of adjustment. Press the button and while you are doing that have some one pull on the door. Once it is open bend the metal tab on the door outwards and it should work fine.
Old Dec 29, 2007 | 09:03 AM
03aeroZ's Avatar
03aeroZ
sometimes the plastic strap that holds the gas cap gets looped around the notch that holds the door in. you have to do what the above post says and have someone unhook the strap...used to happen to me all of the time for some reason.
Old Dec 29, 2007 | 09:21 AM
NewZ84's Avatar
NewZ84
which way is the door suppose to open so i don't pull the wrong side
Old Dec 29, 2007 | 09:27 AM
Jay'Z's Avatar
Jay'Z
The door opens to the right as your pushing it in on the right corner or pulling it on the left side to the right.....
03aeroZ's Avatar
03aeroZ
well....push one side in with the button held in....what ever side dips in is the side that will open
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
roadmax
Sep 12, 2015 05:55 PM
