My Z Won't Start... and the Dealership is stumped :-(
Old Jan 4, 2008 | 03:53 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Electrical issues is the reason I ripped apart my car and parted it so I know what your feeling. Hopefully you don't have one of the U1000 codes. Those really suck. Have them check the inline relays to the ECU and the BCM. This is all under them assulption that they correctly coded the new components to work together properly.
Old Jan 5, 2008 | 04:27 AM
bcheng4jc's Avatar
bcheng4jc
same thing happened to my Z when i still had it. it wouldnt start one morning. had it towed to the dealer. it was there for 2 weeks and they did everything and didnt know what it was. they reprogrammed my Z so many times, replaced my keys, etc. turned out....there's a harness for the unit that reads/senses the key fobs code and whatnot in the steering wheel column next to the harness for the bose noise cancelling unit. it had come loose and the car wasnt able to recognize my key and the car wouldnt start. so even after replacing my key's and reprogramming and whatnot, the car still wouldnt start cause it couldnt recognize all the changes they made. did you ever do the bose/resistor mod? only thing i could think of....good luck!
Old Jan 5, 2008 | 04:51 AM
RM350Z's Avatar
RM350Z
^ good one!!!
Old Jan 5, 2008 | 11:32 AM
Corradoslc7's Avatar
Corradoslc7
bcheng4jc, I doubt it's the keys/immobilizer as the op stated the car recognizes the key and will turn the engine over, it just won't fire up. If the dealer is sure it's not a fuel issue then it must not be getting either spark or air.
Old Jan 5, 2008 | 02:46 PM
Tim@WestCovinaNissan's Avatar
Even with an unprogrammed key the engine will still turn over but it will not start. Good luck with this one. Can't say I've had any with this exact problem. Hope the dealer can figure it out. I've also heard good things about that dealer so they will figure it out....sometimes it just takes awhile. It usually turns out to be something easy/dumb. Overthinking is a terrible thing.
Old Jan 5, 2008 | 03:13 PM
Corradoslc7
My bad I guess I couldn't imagine that being possible. As it could cause damage if someone kept cranking the engine over and didn't know why the car wouldn't start.
Old Jan 5, 2008 | 03:31 PM
asianflip06's Avatar
asianflip06
Im having the same issue with a 03 Altima with the VQ35 at my nissan dealership. Sounds like we have the same issue. You need to have them perform a Voltage drop test on the ECM power and grounds and verify its less than .1. Also have them use the consult 3 and probe at the ECM terminals for Crank shaft signal and both Cam(s) and get a nice Scope pattern and send the readings off to Techline to have a rep anaylize the data. ALso one thing i noticed was the Intake Valve timing on both banks were stuck at 64degress which would indicate a open circuit meaning that no cam signal is being sent to the computer. Right now we are at the ECU being at fault. and its being overnighted as we speak.... Let me know what problem your Z faces if they get somewhere...
Old Jan 5, 2008 | 08:22 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
All right guys! This happend to my car.
ForgedPerformance took them over two day working on my car to find out the problem.
My car would turn over but not start.
Once all the fuses are checked and all are good.
Have them unplug and re plug the crank angle sensor. If it starts great have them replaced, if it doesnt start have them replace them. Mine went bad during a track day while on the track.
Have those monkey's replace the crank angle sensor it a fast easy check..
Old Jan 6, 2008 | 10:21 AM
Al_s14's Avatar
Al_s14
Originally Posted by HondaKiller
if it is cranking just not turning over
dude, thats an oxymoron
you guys do realize that giving advice to the OP at this point is pointless right? last thing a technician will do is listen to a customer who could not fix the car himself. especially since you will have to give that advice through the service writer. obviously they may have someone with no experience working on it which will extend time of the repair but still same thing...
scruffyburritos, just let them do their thing eventually they will find out what the problem is. just be glad its under warranty.
Old Jan 11, 2008 | 04:24 PM
scruffyburritos's Avatar
scruffyburritos
yeah, i agree with you 110%. and it's not that i want to tell the guys in the shop what to do... just want to be able to bounce ideas out there for them. they don't have to admit it, but i could possibly throw something out there they haven't thought of and it might work or lead them in the right direction. anything is worth a shot in this situation honestly. and i don't just talk to the service writer. i always make sure i know who is working on my car and talk to them as well. hell, at some DEALERSHIPS, not just backwoods shops, ive even been able to just waltz around the shop.
anyway, they are now replacing the ENGINE HARNESS. and of course it's on BACKORDER. they put in the order SATURDAY 1/5/08 and figured it would be no later than Friday 1/11/08 that it would come in......
.....wait for it.....
......9:30 this morning they called and i was all excited when I saw "Auto Mike" pop up on my phone. I KNEW THIS WAS FINALLY IT! instead he just wanted to let me know the part is still on backorder and they have no idea at all when it will even ship to them let alone get there.
i miss my baby so much
Old Jan 11, 2008 | 05:36 PM
Al_s14's Avatar
Al_s14
i know how you feel man. i didnt mean to be so negative above. just had a bad day i know exactly what you mean.
best of luck and please keep us posted i am very curious to see what caused the problem.
PS: its problems like this that makes me think 2ce about owning a nissan. i work for nissan an drive one but i would never recommend a used newer nissan to one of my relatives. i worked for Acura(honda) 2 years and literally saw 2 drivability problems and both were pretty straight forward...in half a year working for Infiniti i see wierd ****ed up issues on weekly basis. what i personally learned is that nissans are reliable and dont brake often if ever but when they do...shti will hit the fan and it will be one of toughest problems to diagnose. hate to say it but honda is #1 in my book...but i still love my nissan and will never give it up for a honda.
Old Jan 12, 2008 | 02:53 PM
scruffyburritos
So I was reading Florida Lemon Laws:
Have you taken the vehicle to the dealership or an authorized service agent at least 3 times for the SAME substantial defect or condition or has the vehicle been out of service for at least 15 cumulative calendar days due to one or more substantial defect or conditions?
There must be three repair attempts for the same defect or condition, OR at least 15 cumulative calendar days out of service for one or more defects or conditions, before submitting the Motor Vehicle Defect Notification [14K PDF]. If you do not have the required number of repair attempts or days out of service, then continue to take the vehicle to the dealer for repairs.
Please Note: If your complaint is based on the vehicle being out of service for 15 or more days the manufacturer or its authorized agent has the opportunity to inspect or repair the vehicle. If the vehicle still does not conform to the warranty for a total of 30 or more days and the manufacturer has had the opportunity to repair, you are entitled to request arbitration.
I wonder if I would be successful in pursuing this?
nevermind its a used car
Old Jan 13, 2008 | 03:58 AM
Q8-350's Avatar
Q8-350
scruffyburritos, I had the same thing and dealer was going to drop my engine.
My Z is fixed, here is the link.
http://www.350zmotoring.com/forums/s...ad.php?t=49810
Good luck
Old Jan 13, 2008 | 07:12 AM
scruffyburritos
^^^^^^ very helpful. thanks for that link! glad your baby is up and running again. :-)
Old Jan 14, 2008 | 10:09 AM
scruffyburritos
I'm really upset now... I called the dealership demanding that someone give an answer as to what's going on. They tell me that the team working on my car has the day off and will not be back until tomorrow. I said put the car back together I want it towed. They said no. I am seriously at a loss. They are refusing to get me any type of answer and are refusing to put the car back together. Told me to call back after lunch tomorrow and they "might" have an answer.
I thought *** was a good place?
Old Jan 14, 2008 | 03:37 PM
drivenCSZ's Avatar
drivenCSZ
i would take a trip down there if i were you...someone should atleast be able to tell you what steps theyre taking to fix it
Old Jan 14, 2008 | 03:44 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
They can't not give your car i don't think. If you really want it out of there go there and have the police come out there with you. There is a guy over in Tampa that has a bodyshop that has a Consult. He's on the forums. I forget his sn but the Co. name is Turbo Toys and his name is Jim. (813-695-6664) You could have it towed there and he can prob. fix it. If it's been long enough, start the lemon law procedure. There is a chance though it a fuseable link in the harness they are going to replace. If your under warranty though I'd leave it there casue it's all free.
Old Jan 14, 2008 | 04:56 PM
  #38
zxpwr's Avatar
zxpwr
+1 make them give you a rental car for free
they might have already checked.. but my problem was similar, one relay on the IPDM (located beside the battery) doesnt work
Old Jan 15, 2008 | 06:19 AM
  #39
katiesdad7's Avatar
katiesdad7
Remember the movie "Star Trek"? Scotty tells captain Kirk "the more they complicate the plumbing, the easier it is to stop up the drain". New cars are so complex I wonder how they even run sometimes.
Old Jan 15, 2008 | 03:40 PM
  #40
Corradoslc7
Good luck
O8-350, I still don't get how you're car got fixed, if all your valves were stuck open. What was the exact problem that they fixed?
