Switched from Redline to Royal Purple
Old Jun 11, 2003 | 05:59 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
Default Switched from Redline to Royal Purple
I just drained out my MTL/MT-90 Redline tranny oil and replaced it with Royal Purple 75W90 Gear Oil. It took 3 1/2qts.
Once I start the car, and move through different gears, I noticed it is much more smoother when going into the gates. I start driving on 1st, then shift to 2nd, very smooth, seems much more smoother than Redline.. The tranny had notchy 2nd gear and sometimes it would grind even with Redline, that's why I switched to Royal Purple. I will drive some more tomorrow and see if there's more improvements. But so far, I am very impressed!
Btw, when I drained out the Redline tranny oil, it was like watery.. Not as thick as Royal Purple. I know that Royal Pruple is rated differently than the Redline..Maybe that's why it's better..
Royal Purple is GL-4 friendly and is also rated as GL-5. It states that it does not contain anything to can hurt the synchro..
Old Jun 18, 2003 | 08:25 AM
can350z's Avatar
can350z
Default Thanks for the tip....
Will be switching my car to compete RP soon.........
Old Jun 25, 2003 | 01:51 PM
mwaller's Avatar
mwaller
Any updates? Are you still convinced that your tranny is smoother with royal purple? I'm curious to hear how it has worked after a bit of driving. Do you still have hard shifts or grinds when engaging 2nd gear?
2nd gear on my tranny has always been notchy, especially when cold. I swithced to redline MT-90, but the problem is still there. It may have improved slightly, but it still a constant nuisance.
How much better is your tranny wiht royal purple?
Thanks!
Mika
Old Jun 25, 2003 | 03:29 PM
Inova's Avatar
Inova
i've heard from the s2k guys that royal purple is the way to go. i am thinking about switching the stock for rp but i dont know anything about tranny fluid changes......
Old Jun 25, 2003 | 03:39 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
still impressed with Royal Purple.. 2nd gear does not grind for me anymore, but I also learn not to speed shift and take it easy on it. The notchy feeling between each gate has been improved, but not disappear.. I think it's just how the tranny was made..
I was convinced when I drained out the Redline MTL/MT-90 mixature.. It was almost like water!
Royal Purple is thicker and better imo.. cost about the same. It works for me!
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
