Anyone change differential oil yet??? What is the capacity?
hey guys, since search isnt working, coupld you help me out and tell me how much fluid i have to buy for the rear end? i do have the lsd and i just wanted to know the capacities.
thanks
and also the tranny oil is about 3.6quarts right? thanks
thanks
I just changed my transmission and differential oils with RedLine. Just a note: The clearance to put fluid in the trans and diff is very small and requires a long tube to reach without spilling. I had the car on jack stands when I realized that I had to take a trip to the hardware to get a longer length of flexible tubing.
Transmission: I emailed Redline and the tech recommended Redline 50:50 mixture of MTL + MT90—4 quarts. He said that this most closely approximates what Nissan is recommending.
Differential: Redline 75W90--2 quarts. The plug is magnetic on the differential and there was a lot of metal filings adhered to the magnet. I hope that this is just 'fine tuning' the tolerances on the new differential. There was enough metal that if it was on my older car, I would assume that I needed to begin looking for a new differential.
btw I never had the difficult shifting that others have noted, and so I haven't noticed any improvement either.
have changed all of the fluids: brake fluid to ATE Blue at the suggestion of Dave Zechhausen; engine oil to Mobil1 10W30 after 12,000 miles; and now synthetic Redline.
Anyone else following Le Mans today?
I bought two quart cans of ATE Blue brake fluid. I pumped quite a bit of fluid through the lines and still had 1/3 of the tin left. That's a close approximation. I threw the partly used can away.
