Is it too late to abort a radiator flush?
Old Jan 28, 2008 | 12:52 PM
soshiv's Avatar
soshiv
Default Is it too late to abort a radiator flush?
today i started to do a radiator drain and refill and after removing the radiator drain plug and draining the coolant i realized to do a full flush you had to remove the drain plugs in the cylinder block and everthing... well i dont think im prepared to go that far as i am not that mechanically inclined so can i just pour the new coolant back into the radiator top until full and be done with it? or have i already reached a point of no return? again, all i drained was the radiator not the cylinder block or resivoir tank, both of those remained untouched...
Old Jan 28, 2008 | 01:01 PM
soshiv's Avatar
soshiv
ok now im freakin out cuz i did that and took the car around the block and now it is running hot, what should i do?
Old Jan 28, 2008 | 01:44 PM
After filling the radiator with water, run the motor with the heater ON. Then drain again.
Old Jan 28, 2008 | 01:46 PM
SuperBlack350z's Avatar
SuperBlack350z
you obviously have air bubbles in the system.
Old Jan 28, 2008 | 01:48 PM
iStan's Avatar
iStan
ZR
You need to bleed the radiator. There is most likely air in the system.
Use the Air bleeded when filling. slightly unscrew and pour in more water/coolant, until fluids come out of the hole. Screw the bleeder back on tight. Turn on car and heater. Wash rinse repeat.
Thanks for the Pic Rookie
soshiv's Avatar
soshiv
i have already filled it back up with 50/50 coolant and i found a thread that said this happens when there is air in the system, which im assuming is what happened since i did not remove the relief plug when i refilled it... so do i still need to redrain and refill or just attempt to get the air out of the system?
Old Jan 28, 2008 | 01:50 PM
iStan's Avatar
iStan
ZR
I would say you're ok just trying to get the bubble out.
Old Jan 28, 2008 | 02:22 PM
soshiv's Avatar
soshiv
ok, update... i started the car and let it run and after a few minutes the fans came on and it started to get hot, i turned the air relief plug and steam came out then coolant, i retightened and waited about 30 seconds and loosened again more steam then coolant, i repeated this until is was only coolant coming out, i then turned the car off and let it sit for about 15-20 minutes and restarted waited 5 minutes and tried the air relief plug again but no steam or coolant came out and i waited about 10 minutes, so i turned the heater on and waited another 10 minutes still no steam or coolant, but the heater will not blow cold now... what should i do?
Old Jan 28, 2008 | 02:24 PM
SuperBlack350z
why would the heater blow cold?
Old Jan 28, 2008 | 02:25 PM
iStan's Avatar
iStan
ZR
HEATER will not blow cold?
soshiv's Avatar
soshiv
blow hot, sorry i was typing faster than my brain was thinking
Old Jan 28, 2008 | 02:27 PM
iStan's Avatar
iStan
ZR
With the car off and cool, fill with more coolant/water, while the air relief is open. Close the air relief when coolant starts to pour out. It took me a while to full air out the system.
Old Jan 28, 2008 | 02:36 PM
soshiv's Avatar
soshiv
ok, i will let it cool off for about another 20 minutes then i will remove the radiator cap and fill with coolant with the drain plug open like you said, after that what do i do?
Old Jan 28, 2008 | 02:38 PM
iStan's Avatar
iStan
ZR
Pray it works?
Old Jan 28, 2008 | 03:00 PM
soshiv's Avatar
soshiv
ok car is cool and radiator cap is off and air plug is open, now do i start the car and start filling it or fill it with the car off? and should i run the heater?
Old Jan 28, 2008 | 03:19 PM
iStan's Avatar
iStan
ZR
I would try with the car off, fill as much as you can. Close everything up, start car.
Old Jan 28, 2008 | 03:21 PM
soshiv's Avatar
soshiv
i filled the radiator until it started overflowing but nothing came out the relief valve
Old Jan 28, 2008 | 03:23 PM
iStan's Avatar
iStan
ZR
haha, this is going to sound funny, play it the coolant hose going from the rad to the block on the passenger side. Should get some movement of the coolant.
Old Jan 28, 2008 | 03:27 PM
SuperBlack350z
I think you should let a shop to do your future maintainence. You're lucky to have Istan here to help you out. Sorry, i feel a bit lazy today.
keep massaging the lines.
Old Jan 28, 2008 | 03:33 PM
iStan's Avatar
iStan
ZR
Just keep working the lines, starting the car filling reliefing, etc. It'll take a while, but I'm sure you'll get it
