Help! Something fell into the transmission...
Old Jun 16, 2003 | 08:05 PM
the_bode's Avatar
the_bode
Default Help! Something fell into the transmission...
...or maybe not, I am not sure, but it sure freaks me out!
I have a Touring MT, and (don't ask me why) I removed the little ashtray-like coin holder just behind the stick in the central console. I turned it over, and a small piece of plastic, about the size of a dime, fell right into the hole which leads under the central console, underneath the parking brake and who knows what else.
Does anyone know how to remove the central console cover? I found three screws: one underneath the ashtray (actually, probably more like a coin holder), and one on each side by the seats. However, even after I unscrew all three I can't lift the console unit as it seems to be attached to the console boot/finisher.
I read the Nissan Technical Bulletin NTB02-102 (http://members.***.net/vqracer/NTB02-102.pdf), and it says "Refer to page IP-14 of the 2003 350Z Electronic
Service Manual for console boot removal information." Great!!! Does anyone have the service manual?!?
Any and all help would be greatly appreciated...
Old Jun 17, 2003 | 05:01 PM
dr_gallup's Avatar
dr_gallup
I don't think you have a thing to worry about. That piece is not inside you transmission, it is sealed. It probably fell out or will fall out, did you look on the ground where you were parked? (I assume you WERE parked!) There is a very remote chance that it could jam your shift linkage but I doubt it.
Old Jun 18, 2003 | 07:41 AM
the_bode's Avatar
the_bode
Thanks.
I actually took the car to the dealer to fix an unrelated problem (rear view mirror rattle), and I also asked them to get the piece of plastic out. I was told that the transmission (and the driveshaft, etc.) are sealed and nothing you drop through the hole in question can get anywhere near them. However, they did say that whatever was dropped in there could get caught in the parking brake mechanism, so I was glad I got rid of it.
Later,
Bode
Old Jun 19, 2003 | 05:52 AM
ricks350z's Avatar
ricks350z
hey ur not the only that did this..i took the tray out and put my keys there and it went down the hole but lucky i was manage to get it out asap...scare the **** out of me..
thx goodness i got it out and will never put anything in unless the tray is in there...!!!
Juztin
Nov 22, 2015 07:03 AM
Dymsi
Sep 29, 2015 11:32 AM
Ace2347
Sep 22, 2015 03:12 AM
themyst
Jul 31, 2005 02:35 PM
