p1614 and p1615 nats malfunction
Old Feb 4, 2008 | 10:37 PM
lckillah's Avatar
lckillah
Default p1614 and p1615 nats malfunction
ok so i've been doing some research about the codes that i got. i know it is the anti theft thing from nissan. i read somewhere that u won't b able to start ur car with these codes. but i could start my car but problem is, battery discharge easily i dunno if it was from the codes or bad battery. any help?
Old Feb 4, 2008 | 10:40 PM
black06z's Avatar
black06z
I have that problem. I just wiggled the connections a little and I can get it started it again. I just bit the bullet and made an appointment with the dealership for tomorrow, because it has to be reprogrammed anyways. I hope it doesn't cost too much.
Old Feb 4, 2008 | 10:42 PM
lckillah's Avatar
lckillah
did u have battery problems??? i turn off my engine and then when i come back, battery is dead. could it b bad battery or is it from codes?
Old Feb 4, 2008 | 11:30 PM
boogy886's Avatar
boogy886
How old is your battery? I'm pretty sure the fault codes wouldn't drain your battery...if you have an 03 with the original battery its about time to get a new one. Might start there it will definitely be cheaper than taking it to the dealer. Especially if you pay them $100+ just to tell you that you need a new battery...
Old Feb 5, 2008 | 06:56 AM
Tim@WestCovinaNissan's Avatar
Either the battery went completely dead and caused the codes or you tried to start the car with a bad key. Get your battery replaced and go from there.
Old Mar 9, 2008 | 01:53 PM
viperbe's Avatar
viperbe
Did you ever figure out what caused this?
I have the same problem p1614. My car randomly does this..but everytime i clear at the codes and it deciedes that it doesnt want to start. i pull the code and everytime its p1614. I have already replaced my battery and bought new keys and it still does it. Its very random. It does it when its cold and sometimes when im below 1/4 tank of gas....
when it does this the car seems like it wants to come on fine but will not crank. You can hear the car try to crank but will not turn over.. Im about to just pay the +100 for the dealer but i wanted to know if you figured this issue out...
Everything i read about the code says nissan anti theft. I even got the shop manual and it says use a consult..well i dont have that kind of cash..or shop around so i guess i gotta go to the dealer. Any one else got any idea, i was thinking either fuel pump or starter...but it does it randomly almost like when the car feels like it..
Old Mar 25, 2012 | 10:09 AM
jcmuscarello's Avatar
jcmuscarello
Anybody find the issue with the P1614 code??
lolwatbro
Oct 9, 2021 04:58 AM
Dr.Paulyy
Jul 29, 2019 07:45 AM
disturbed2483
Aug 5, 2009 05:54 PM
amai21
Nov 30, 2006 07:09 PM
350trackz
Nov 6, 2003 12:49 PM
