jack/ramp preference to lift our Z's...
Old Feb 13, 2008 | 09:08 AM
fishbait's Avatar
fishbait
Default jack/ramp preference to lift our Z's...
Hi! what method/type/brand/model of jacks/ramps do you use to lift up your Z? I am used to crawling under my 4x4 but need a jack low enough to use on the Z. She is ready for the Amsoil! -your preferences please.....?
Old Feb 13, 2008 | 04:35 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
any jacks will do just make sure they are low profile jack that way when you lower your car they will fit.
Old Feb 13, 2008 | 05:58 PM
anotheraznguy's Avatar
anotheraznguy
i use takata lds ramps.
they are super low
and for jack i use low aluminum from costco.
Old Feb 13, 2008 | 06:23 PM
JFAIR's Avatar
JFAIR
rhino ramps
Old Feb 13, 2008 | 08:57 PM
JETPILOT's Avatar
JETPILOT
Duralast aluminum jack from AutoZone for $99. And the aluminum stands too. I love mine.
http://www.autozone.com/images/in_ou...g2_0405_07.pdf
JET
Old Feb 14, 2008 | 07:19 PM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I use my 12k Rhino Ramps if at all possible, unless I have to take the tires off, then I drive up on some 2x8 blocks and use a 3.5 ton trolley jack and stands.
Chris
Old Feb 15, 2008 | 07:28 AM
VO...'s Avatar
VO...
Administrator
JET
Thanks for the link...
Old Apr 7, 2008 | 11:06 AM
donricouga's Avatar
donricouga
JET
Do these work on the G35 coupe as well? Where is the Jack Point on the car and where to put the stands?
Old Apr 7, 2008 | 11:23 AM
Z04's Avatar
Z04
yes it should, and your jack points are located in your owner's maual
Old Apr 7, 2008 | 03:14 PM
thekinn's Avatar
thekinn
Default jack points
refer to this post for jack points.. on a z at least.
https://my350z.com/forum/showthread....ht=jack+points
searched the maintenance forum for jack points - titles only.
Old Apr 7, 2008 | 05:11 PM
Cannysage's Avatar
Cannysage
aluminum jacks all suck. i went through 2 of them already. Now I use a big ol Craftsman 4 ton jack and happy as hell. still have to use a smaller jack for the front, for clearance, but i don't mind.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
350Z_Al
Oct 29, 2020 07:44 PM
Alexreyes
Sep 30, 2015 11:30 PM
